I want to utilize cuda to speed up the current project.
I have written the kernal thread. And I want to call the kernal thread in a .cpp file. But when compiling the project, there are some errors:
[yongzhao@205 threads]$ make
threads.cu:10: error: âblockDimâ was not declared in this scope
threads.cu:10: error: âblockIdxâ was not declared in this scope
threads.cu:10: error: âthreadIdxâ was not declared in this scope
main.cpp:36: error: expected primary-expression before â<â token
main.cpp:36: error: expected primary-expression before â>â token
you are trying to compile the .cu with a standard c++ compiler (g++ ?) which doesn’t recognize cuda stuff (and specifically the blockDim etc. code), or you didn’t declare your kernel as a kernel (you need to give it the global attribute) which seems more plausible as you didn’t get an error (or at least didn’t mention it) about not recognizing it (which g++ should complain about)
You are trying to make a kernel call from the cpp file which is definitely not compiled with nvcc (never tested whether nvcc would even agree to compile it as cuda code) and thus the kernel paradigm <<< dimGrid, dimBlock >>> is not recognized.
You should:
a. make sure the cu file is compiled with nvcc (remove the @ from the compilation rules in the make file if they are there to print the actual compilation command and submit that)
b. make sure the kernels are marked as such (global)
c. make the kernel call from the .cu file and make a wrapper function to be called from the .cpp file to make that happen
