**• Hardware Platform (Jetson / GPU)GPU
**• DeepStream Version6.1
**• TensorRT Version8.4
**• NVIDIA GPU Driver Version (valid for GPU only)3090
**• Issue Type( questions, new requirements, bugs)questions
Dear professor:
I meet a problem that I hope to change the resource when the deepstream-app. I know the reference code"runtime_source_add_delete ", and I run the demo success. So my problem is:
(1) There are many codes about our project in the deepstream_app.c and gst_dsexample, so if I just use “runtime_source_add_delete”, many function can not be used directly, such as drawing lines in the frame, sink as the rtsp. So I hope to embed the “runtime_source_add_delete” method into deep_stream_main.c. So it is difficult to me.
(2) Is there an easy way to change the source when deepstream-app running? such as I change the rtsp IP in somewhere?
(3) If there is no way to do, how could I embed the “deepstream_test_rt_src_add_del”
? I found the key function is “g_timeout_add_seconds(…)”, is that right? if I just copy the “add_source” function and the related code into deepstream_app_main.c is ok>
I need a direction.
Thank you very much.
