Hi, since I found some cuda files in my applications usually require much much time to compile. I hope when changing some other cu files, only the changed files will be compiled and linked. I am using Visual Studio 05, anyone has such experience? Thanks in advance.
Related topics
| Because of the slightest change in CU/CUH files, you need to re-compile whole solution, how to configure the partial compilation? | 0 | 502 | December 15, 2017 | |
| Compiling from command line | 7 | 4238 | February 10, 2010 | |
| Why changing linker options triggers whole recompilation? | 0 | 365 | November 13, 2017 | |
| compile cuda file inside a c project | 1 | 1270 | March 25, 2015 | |
| file dependency when compiling in vs2005 | 1 | 6321 | October 20, 2010 | |
| NVCC not linking after code changes in cu header | 0 | 495 | April 14, 2022 | |
| NVCC in Visual Studio 2010 | 1 | 1136 | August 14, 2011 | |
| Visual Studio C++ Functions Compiled in .CU Files Not Linking. Kernel Declaration Syntax Generates Syntax Errors | 0 | 48 | July 26, 2024 | |
| How to tell Visual Studio to build .cu files | 4 | 10814 | October 23, 2018 | |
| How to create .cu file | 2 | 4912 | June 3, 2010 |
