I’m trying to compile a .cu file containing a method called by a .c file. The compilation of the two files is ok (even if I had to add a useless main method in the .cu file to compile it) but I can’t link it.
I’m using a script to do this (I had a lot of problem with the Makefile I did, I will try again to make it when I will be able to create an executable) :
[codebox]gcc -c incrementation-pu.c -o incrementation-pu.o -lstarpu
nvcc incr-kernel.cu -o incr-kernel.o -I /usr/include/cuda -I /usr/local/cuda/include -I /usr/local/cuda/lib/ -L /home_nfs/fremals/local/starpu/lib/ -L /usr/local/cuda/lib
gcc -o test incrementation-pu.o incr-kernel.o -lstarpu -L /home_nfs/fremals/local/starpu/lib/[/codebox]
The error I obtained is a really good one :
[codebox]incr-kernel.o: In function `_start’:
/build/buildd/glibc-2.9/csu/…/sysdeps/x86_64/elf/start.S:65: multiple definition of `_start’
/usr/lib/gcc/x86_64-linux-gnu/4.3.3/…/…/…/…/lib/crt1.o:/build/buildd/glibc-2.9/csu/…/sysdeps/x86_64/elf/start.S:65: first defined here
incr-kernel.o: In function `_fini’:
/build/buildd/glibc-2.9/build-tree/amd64-libc/csu/crti.S:37: multiple definition of `_fini’
/usr/lib/gcc/x86_64-linux-gnu/4.3.3/…/…/…/…/lib/crti.o:/build/buildd/glibc-2.9/build-tree/amd64-libc/csu/crti.S:37: first defined here
incr-kernel.o:(.rodata+0x0): multiple definition of `_IO_stdin_used’
/usr/lib/gcc/x86_64-linux-gnu/4.3.3/…/…/…/…/lib/crt1.o:(.rodata.cst4+0x0): first defined here
incr-kernel.o: In function `__data_start’:
(.data+0x0): multiple definition of `__data_start’
/usr/lib/gcc/x86_64-linux-gnu/4.3.3/…/…/…/…/lib/crt1.o:(.data+0x0): first defined here
incr-kernel.o: In function `main’:
(.text+0xec): multiple definition of `main’
incrementation-pu.o:incrementation-pu.c:(.text+0xe6): first defined here
incr-kernel.o: In function `_init’:
/build/buildd/glibc-2.9/build-tree/amd64-libc/csu/crti.S:25: multiple definition of `_init’
/usr/lib/gcc/x86_64-linux-gnu/4.3.3/…/…/…/…/lib/crti.o:/build/buildd/glibc-2.9/build-tree/amd64-libc/csu/crti.S:25: first defined here
/usr/lib/gcc/x86_64-linux-gnu/4.3.3/crtend.o:(.dtors+0x0): multiple definition of `DTOR_END’
incr-kernel.o:(.dtors+0x8): first defined here
/usr/bin/ld: error in incr-kernel.o(.eh_frame); no .eh_frame_hdr table will be created.
collect2: ld returned 1 exit status
[/codebox]
It sees that there is two mains now, but he doesn’t want to compile if I don’t put another main in the .cu file.
To be honest, I’m completely lost (i’m searching on forums for 3-4 hours but i don’t find how to compile my files :s).
Can someone help me please ?
Thank you !!
