I want to test GPIO interrupt on TX2. There are four user keys available on board i.e Power, Reset, Recovery and volume. Can I configure any of the key to generate GPIO interrupt? Idea is to generate GPIO interrupt when key is pressed.
Thanks,
Vishnu
I don’t know much about the 4 buttons you have mentioned above, other than their intended purpose. But I did something similar on the TX1, this method should be the same for the TX2.
I followed this guide: http://www.jetsonhacks.com/2015/12/29/gpio-interfacing-nvidia-jetson-tx1/
with this software: https://github.com/jetsonhacks/jetsonTX1GPIO
Dear david_evans_g ,
Thanks for reply. Customer use case is to generate gpio interrupt using existing keys.
I am trying to achieve following:
Volume down key is configured as gpio-keys in TX2 in dts file arch/arm64/boot/dts/nvidia/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-cvb-prod-p2597-b00-p3310-1000-a00-00.dtsi
gpio-keys {
compatible = "gpio-keys";
gpio-keys,name = "gpio-keys";
volume_down {
label = "Volume Down";
gpios = <&tegra_aon_gpio TEGRA_AON_GPIO(FF, 2) GPIO_ACTIVE_LOW>;
linux,code = <KEY_VOLUMEDOWN>;
I want to use above key to generate GPIO interrupt but as it is already mapped I can’t use it. So I commented out volume down key code in dts.
I am able to export GPIO=314 (GPIO number for Volume down is 314 - GPIO3_PFF.02 ) using sysfs file system
root:~# echo 314 > export
root:~# echo "rising" > edge
/* Checking Interrupt status for gpio pin - before Pressing key*/
root:~#cat /proc/interrupts | grep 373
373: 0 0 0 0 0 0 tegra-gpio-aon 58 Edge gpiolib
/* Interrupt status after pressing volume down key - Pressed 7 times, interrupt generated 7 times
root:gpio314# cat /proc/interrupts | grep 373
373: 7 0 0 0 0 0 tegra-gpio-aon 58 Edge gpiolib
This works fine. Now I want to achieve same using kernel module. I have written kernel module using following APIS
Allocate specific GPIO using "gpio_request()"
Acquire specific IRQ for GPIO Pin using "gpio_to_irq(GPIO)"
Register IRQ handler using "request_irq()
Set IRQ type Raising/Falling/Level? triggered
Use free_irq() and gpio_free() to release allocated resources.
Module is registered without any error. gpio_to_irq(GPIO) api return IRQ=373, registered interrupt handler with IRQ without any error.
PROBLEM:
When pressing volume down key interrupt is not generating. Wondering what is the problem. I have read some where we need to assign correct pinmuxing for the GPIO in dtb file to achieve this. I’m not sure how to do this. Any help appreciated.
Can I achieve same without commenting volume down key code in dts file?
Regards,
Vishnu
