Hello!
Is there a function on the DEVICE that convert double array to float array? from CUDA or CUBLAS?
Or should I transfer the array out to HOST then use std::transform, and then transfer into DEVICE again?
Hello!
It’s a fairly trivial kernel to write yourself…
