• Hardware Platform (Jetson / GPU) AGX Xavier
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
I try to modify the gstdsexample.cpp to have two sink pads.
In the gst_dsexample_class_init, I add one more sink pad as below
> gst_element_class_add_pad_template (gstelement_class,
> gst_static_pad_template_get (&gst_dsexample_sink_template));
Questions:
- do I need to modify _start, _stop, _set_caps accordingly? how?
- how do I modify gst_dsexample_transform_ip to receive two inbuf which associated with each sink pad respectively?
- is there an example source code for multiple sink pads plugin? prefer two GST_PAD_ALWAYS example and process both sink pad bufs and frames metadata at the same time instead of sequentially like mux.
Thank you very much for your help.
