Hi everyone
I am having problems with my code when passing it to the device, now my host matrix is created without problems in the allocate_init_2Dmatrix call function and in turn it already places the values inside the matrix, when creating the ad pointer corresponding to the one that will go to the device in the solver function is not carrying anything and immediately leaves the function, I have placed a printf inside the solver to verify the value of the pointer but I do not print anything, this is my code, I have implemented it as the options I found but the problem I think lies in that to go to the kernel should be the address of a pointer float, ie a float ***, this is my code, if someone can help me I would appreciate it a lot
#include <stdio.h>
#include <stdlib.h>
#include <sys/time.h>
#define MAX_ITER 1000000
#define MAX 100 //maximum value of the matrix element
#define TOL 0.000001
// Generate a random float number with the maximum value of max
float rand_float(int max){
return ((float)rand()/(float)(RAND_MAX)) * max;
// Allocate 2D matrix
void allocate_init_2Dmatrix(float ***mat, int n, int m){
int i, j;
*mat = (float **) malloc(n * sizeof(float *));
for(i = 0; i < n; i++) {
(*mat)[i] = (float *)malloc(m * sizeof(float));
for (j = 0; j < m; j++)
(*mat)[i][j] = rand_float(MAX);
// solver
__global__ void solver(float ***matd, int n, int m){
float diff = 0, temp;
int done = 0, cnt_iter = 0;
int j= blockIdx.x*blockDim.x + threadIdx.x;
int i= blockIdx.y*blockDim.y + threadIdx.y;
printf("valor de matd:%f\n",***matd);
while (!done && (cnt_iter < MAX_ITER)){
diff = 0;
if (i < n - 1 && j < m - 1){
temp = (*matd)[i][j];
(*matd)[i][j] = 0.2 * ((*matd)[i][j] + (*matd)[i][j - 1] + (*matd)[i - 1][j] + (*matd)[i][j + 1] + (*matd)[i + 1][j]);
diff += abs((*matd)[i][j] - temp);
// printf("diff:%f\n",diff);
if (diff/n/n < TOL)
done = 1;
cnt_iter ++;
if (done)
printf("Solver converged after %d iterations\n", cnt_iter);
else
printf("Solver not converged after %d iterations\n", cnt_iter);
int main(int argc, char *argv[]) {
int n;
float **a,**ad;
struct timeval start, end,start1, end1;
double mtime, seconds, useconds,x,mtime1, seconds1, useconds1,y;
gettimeofday(&start, NULL);
dim3 DimGrid(10);
dim3 DimBlock(128);
if (argc < 2) {
printf("Call this program with two parameters: matrix_size communication \n");
printf("\t matrix_size: Add 2 to a power of 2 (e.g. : 18, 1026)\n");
exit(1);
n = atoi(argv[1]);
float *temph[n];
printf("Matrix size = %d\n", n);
allocate_init_2Dmatrix(&a, n, n);
// cudaMalloc(&ad,n*n*sizeof(float ));
// cudaMemcpy(ad,a,n*n*sizeof(float),cudaMemcpyHostToDevice);
// Allocate 2D array in Device
cudaMalloc((void **)&ad,n*sizeof(float *));
for (int i = 0; i < n; i++){
cudaMalloc(&temph[i], n*sizeof(float));
cudaMemcpy(ad,temph,n*sizeof(float *),cudaMemcpyHostToDevice);
cudaMemcpy(temph[i],a[i],n*sizeof(float *),cudaMemcpyHostToDevice);
gettimeofday(&start1, NULL);
//printf("valor de ad:%f\n",&a);
solver<<<DimGrid, DimBlock>>>(&ad, n, n);
cudaMemcpy(a,ad,n*n*sizeof(float),cudaMemcpyDeviceToHost);
cudaFree(ad);
gettimeofday(&end1, NULL);
seconds1 = end1.tv_sec - start1.tv_sec;
useconds1 = end1.tv_usec - start1.tv_usec;
mtime1 = ((seconds1)*1000+ useconds1/1000);
y=mtime1/1000;
printf("\nTiempo calculo de funcion solver es: %g segundos", y);
gettimeofday(&end, NULL);
seconds = end.tv_sec - start.tv_sec;
useconds = end.tv_usec - start.tv_usec;
mtime = ((seconds)*1000+ useconds/1000);
x=mtime/1000;
printf("\nTiempo total de programa: %g segundos\n", x);
return 0;
