Hardware Platform (Jetson / GPU) NX • DeepStream Version 6.11 • JetPack Version (valid for Jetson only) 5.02 • TensorRT Version 8.4
My source is a 800x512 rtsp h264 stream. I plan to send the h264 with ffmpeg and attached with SEI info. It is a win7 desktop connected via micro-usb.
I will write timestamp or sequence number on SEI, my aim is get the SEI info, and later send the inference result together with SEI back to the win7 computer.
I am not sure on which plugin to realize it, please help.
You can receive (as client) and send (as server) RTSP stream directly in Jetson board if you connect a network cable to your Jetson board. /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream_sink_bin.c, /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream_source_bin.c
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
