Hello Everyone,
I have a RAG application that is working fine and because of the limited space in Jetson Orin Nano Developer Kit, I am using a quantized mistral 7b instruct model.
I would greatly appreciate it if someone can assist me on step by step ways of deploying the RAG application on the Jetson Orin Nano Developer Kit.
Thank you
There are the guideline in jetson-container
Please refer to below link
I have deployed the model on the edge device. However, I am getting the error below each time I tried to run the RAG application. I would be glad if someone can assist me with this.
RuntimeError: Failed to import transformers.integrations.bitsandbytes because of the following error (look up to see its traceback): CUDA Setup failed despite GPU being available. Please run the following command to get more information: python -m bitsandbytes Inspect the output of the command and see if you can locate CUDA libraries. You might need to add them to your LD_LIBRARY_PATH. If you suspect a bug, please take the information from python -m bitsandbytes and open an issue at: GitHub · Where software is built
Although, each time I cd into bitsanbytes and I ran the code: python -m bitsandbytes
I got this:
++++++++++++++++++++++++++ OTHER +++++++++++++++++++++++++++
COMPILED_WITH_CUDA = True
COMPUTE_CAPABILITIES_PER_GPU = [‘8.7’]
++++++++++++++++++++++ DEBUG INFO END ++++++++++++++++++++++
Running a quick check that:
+ library is importable
+ CUDA function is callable
WARNING: Please be sure to sanitize sensible info from any such env vars!
SUCCESS!
Installation was successful!
