Hello forks,
We are trying to use the 5x UART interface of AGX Orin as COM ports. With debug UART enabled, we have noticed that:
- UART C (serial@c280000) is linked to /dev/ttyTCU0
- UART E (serial@3140000) is linked to /dev/ttyAMA0
We tried to remove the “console” related arguments under /boot/extlinux/extlinux.conf, which becomes
APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=8 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
But we still get the following information in the boot-up process
** WARNING: Test Key is used. **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
We are grateful if you would share any related experience or feedback.
