Description
I am using TensorRT engine for inference using Jetson TX2
with engine.create_execution_context() as context:
context.debug_sync = False
# Transfer input data to the GPU.
cuda.memcpy_htod_async(d_input_1, h_input_1, stream)
# Run inference.
print('load profiler')
context.profiler = trt.Profiler()
print('execute')
context.execute(batch_size=1, bindings=[int(d_input_1), int(d_output)])
print('Transfer predictions back from the GPU.')
# Transfer predictions back from the GPU.
cuda.memcpy_dtoh_async(h_output, d_output, stream)
# Synchronize the stream
stream.synchronize()
# Return the host output.
print(h_output.shape)
out = h_output.reshape((1,-1))
return out
Each time context.execute(batch_size=1, bindings=[int(d_input_1), int(d_output)])
it logs the model layers all of them which makes the console not suitable for debugging. I tried to disable it but I couldn’t.
I think the problem is in this method engine.create_execution_context()
as documented in the api this return IExecutionContext with debug_sync
set to True
. I don’t know if this is a bug or not.
I used context.debug_sync = False
but it didn’t stop logging the execution layers.
how I could disable logging the execution layers on the terminal?
Environment
TensorRT Version: 7.1.3.0
GPU Type: Jetson TX2
CUDA Version: 10.2.89
CUDNN Version: 8.0.0.180
Operating System + Version: jetpack 4.4.1
TensorFlow Version (if applicable): 2.3.1+nv20.10
