Hi guys,
I’m wondering how to get better performance of fp16 convolution forward in cudnn?
Environment:
CUDA Version: 12.0
Device: A10
cuDNN version: 8.7
Docker environment: nvcr.io/nvidia/pytorch:23.02-py3
Nvidia Driver version: 525.105.17
Torch Version: 1.14.0a0+44dac51
What I have tried:
- Do algorithms search by cudnnFindConvolutionForwardAlgorithm, and turns out Tensor Core algo (CUDNN_CONVOLUTION_FWD_ALGO_IMPLICIT_PRECOMP_GEMM) with math type (CUDNN_TENSOR_OP_MATH) is faster
- Switch the compute type between float32 and float16, and turns out using float32 as compute type is faster for some reason
- Changing tensor format from NCHW to NHWC
And finally with these params:
n: 2
h: 64
w: 64
in channel: 640
out channel: 640
kernel size: (3,3)
stride: (1,1)
I got GPU time cost: 0.442778 ms, which is indeed faster than torch: 0.67805 ms
Then I tried TensorRT by doing trtexec --onnx=conv.onnx --fp16
It turns out that time cost could be 0.363779 ms
I believe that TensorRT is also using cuDNN to do conv, so there must be something else that I can do to speed up my conv code.
Here is my code that does conv2dWithBias and perf check. Just modify the suffix from .txt to .cu should make this compile
test_cudnn_cu.txt (18.4 KB)
Here is my Python script that does torch conv speed test and generates conv.onnx
test_cudnn_py.txt (980 Bytes)
Thanks!!!
