How to get output frame data in yolo apps
I managed to run deepstream_app_config_yoloV3.txt successfully. Now I want to change the app according to my personal requirement. Imagine I want to print “Person detected” in the terminal when the yolo detector identify a person in a frame.
I went through the files in objectDetector_Yolo folder, but I wasn’t able to find the relevant file which I can use to do my task. Can you please give me a little guidance ?
bump !
After going through the code I found the solution.
nvdsparsebbox_Yolo.cpp file contains the details of the detected objects. maxIndex variable carries the object label index which is related with labels.txt file.
Good to know issue has been resolved, thanks for the update!
