Hello!
I would like to ask whether there is a way to retrieve a pointer to a kernel, by its name.
Thank you!
Hello!
Thank you!
You can do that in device code. Ordinary host code cannot directly use a device code entry point (function name) as a pointer.
You can retrieve a kernel pointer in device code using a typical C++ method. I’m not sure what if anything that could or would be used for.
Ok I see, thank you!
