I am geting the metadata from REDIS with the result of container DeepStream 7 Yolov8s test but i can’t find the image/frame.
i have this metadata:
'{ "version" : "4.0", "id" : "348945", "@timestamp" : "2024-08-13T14:10:05.137Z", "sensorId" : "video_test", "objects" : [ "39634|361.462|475.645|405.39|591.268|Person|0", "39625|422.592|489.527|461.835|585.446|car|0" ] }'
But i have only the boxes, not the image frame.
How can i get the image/frame from this information/metadata?
kesong
7
Which application are you using? Are you using AI NVR from JPS: AI NVR — Metropolis on Jetson documentation 0.1.0 documentation
DeepStream doesn’t send the object corp or video frame to Redis currently.
I am using AI NVR,
I saw that we can use API to GET the image from STORAGE like:
Is this the best way to get the frame using @timestamp (var that exist on REDIS message) ?
I am trying this command and i received the frame with success!
http://localhost:30080/vst/api/v1/live/stream/8a22c104-d41f-4d8b-aec4-175984ad3842/picture?startTime=2024-08-14T15%3A03%3A21.503Z
kesong
9
Yes, you are right. Application can get image or video clips form VST.
system
Closed
10
