I’ve an AGX Orin Dev kit with JetPack 5.1 (Rev 1).
I tried to install Torch and Torchvision working with Cuda 11.4 (which is the Cuda version available with Jetpack 5.1).
So following this link (Installing PyTorch for Jetson Platform) I was able to install torch-1.14.0a0+44dac51c.nv23.02-cp38-cp38-linux_aarch64, but I can not find the equivalent torchvision package.
Where can I find it ?
My aim is to be able to work with Yolo (from ultralytics) using CUDA and not CPU.
Hi @dgotfroi ,
Usually if the packages are not readilly available is best just to build from source. And the bonus is that sometimes it gives an extra bump in performance.
Here is the source repo and according to them you just need to have Torch installed and do:
python setup.py install
Before doing so I suggest to enable jetson-clocks to speed things up and enable all cores.
There are some ways to do that, here is one using cmd, and another is using jtop.
