Hello Everyone, Hope you all doing good.
I have URL for Nvidia NGC APIs so i want to make API call to run job creation on DGX ACE instance.
I have created NGC API key but each time i provide 5 to 6 information that normally we do in web interface like
aceInstance,dockerImageName,aceName,jobPriority,resultContainerMountPoint,runpolicy--> preemptClass,jobOrder -
The total number of parent parameter is 38 and some has sub parameter but i am using the above information to create a job but every time i got
UNAUTHORIZEerror on response so i need help why i am unable to make a call. -
Here is the API call for job creation:
curl -X 'POST' \
'https://api.ngc.nvidia.com/v2/org/org_name/team/tema_name/jobs' \
-H 'accept: application/json' \
-H 'NV-AuthN-Token: N2tpbjd2Z####YzBiMGNsY2l##########mLTlmMWYtM#####MTllOWEz' \
-H 'Content-Type: application/json' \
-d '{
"containerResources": {
"requests": {
"cpu": "string",
"memory": "string"
"limits": {
"cpu": "string",
"memory": "string"
"expTrackingParams": {
"projectName": "string",
"type": "NONE",
"name": "string"
"userLabels": [
"string"
"aceId": 0,
"resultsetMounts": {
"containerMountPoint": "string",
"id": "string",
"mountMode": "RO"
"isLabelLocked": true,
"jobType": "BATCH",
"aceInstance": "################",
"dockerImageName": "##############",
"aceName": "#############",
"jobVolumes": [
"name": "string"
"systemLabels": [
"string"
"envs": [
"name": "string",
"value": "string"
"healthCheck": {
"initialDelaySeconds": 0,
"httpGet": {
"path": "string",
"port": 0
"timeoutSeconds": 0,
"periodSeconds": 0
"jobOrder": 0,
"sidecarContainers": [
"containerName": "string",
"requests": {
"cpu": "string",
"memory": "string"
"limits": {
"cpu": "string",
"memory": "string"
"useImageEntryPoint": true,
"dockerImageName": "string",
"envs": [
"name": "string",
"value": "string"
"healthCheck": {
"httpGet": {
"path": "string",
"port": 0
"periodSeconds": 0
"publishedContainerPorts": [
0
"portMappings": [
"protocol": "string",
"name": "string",
"hostPort": 0,
"hostName": "string",
"hostIP": "string",
"containerPort": 0
"entryPoint": "string",
"resultContainerMountPoint": "string",
"command": "string",
"datasetMounts": [
"id": 0,
"uuid": "string"
"jobVolumeMounts": [
"name": "string",
"mountMode": "RO"
"workspaceMounts": [
"id": "string",
"mountMode": "RO"
"reservedLabels": [
"string"
"topologyConstraint": "string",
"id": "string",
"mountMode": "RO"
"description": "string",
"replicaCount": 0,
0
"jobPriority": "##########",
"networkType": "INFINIBAND",
"name": "string",
"mountMode": "RO"
"datasetMounts": [
"id": 0,
"uuid": "string"
"name": "string",
"runPolicy": {
"minTimesliceSeconds": 0,
"expirySeconds": 0,
"totalRuntimeSeconds": 0,
"preemptClass": "###############"
"arrayType": "MPI",
"userSecretsSpec": [
"name": "string",
"allKeys": true,
"keysSpec": [
"envName": "string",
"keyName": "string"
"portMappings": [
"name": "string",
"hostPort": 0,
"hostIP": "string",
"containerPort": 0
"minAvailability": 0,
"initContainers": [
"requests": {
"cpu": "string",
"memory": "string"
"limits": {
"cpu": "string",
"memory": "string"
"envs": [
"name": "string",
"value": "string"
"datasetMounts": [
"id": 0,
"uuid": "string"
"name": "string",
"mountMode": "RO"
"id": "string",
"mountMode": "RO"
"resultContainerMountPoint": "########"
response
"requestStatus": {
"statusCode": "UNAUTHORIZED",
"statusDescription": "Not Authenticated",
"requestId": "c85b9da5-2944662"
how to slove this problem ?
- I also tried to use use Python as mentioned in offifical doc , first they get token then they use get API .
- So i tried token as bearer token in Authorization header but still got the same error??
Kindly help me out in this problem
