I get some errors for my coding sample -
[code]
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include <time.h>
#include <math.h>
#define DATA_SIZE 1048576
#define BLOCK_NUM 32
#define THREAD_NUM 256
int data[DATA_SIZE];
bool InitCUDA()
int count;
cudaGetDeviceCount(&count);
if (count == 0)
fprintf(stderr, "There is no device.\n");
return false;
int i;
for (i = 0; i < count; i++)
cudaDeviceProp prop;
if (cudaGetDeviceProperties(&prop, i) == cudaSuccess)
if (prop.major >= 1)
cudaGetDeviceProperties(&prop, i);
printf("Device Name: %s\n", prop.name);
printf("Total global mem: %1u bytes\n", prop.totalGlobalMem);
printf("Max threads per block: %d\n", prop.maxThreadsPerBlock);
printf("Clock rate: %.2f GHz\n", prop.clockRate*1e-6f);
printf("\n");
break;
cudaSetDevice(i);
return true;
__global__ static void sumOfSquares(int *num, int* result, clock_t* time)
const int tid = threadIdx.x;
const int size = DATA_SIZE / THREAD_NUM;
int sum = 0;
int i;
clock_t start;
if (tid == 0) start = clock();
for (i = tid * size; i < (tid + 1) * size; i++)
sum += num[i] * num[i];
result[tid] = sum;
if (tid == 0) *time = clock() - start;
int* gpudata, *result;
clock_t* time;
cudaMalloc((void**)&gpudata, sizeof(int)* DATA_SIZE);
cudaMalloc((void**)&result, sizeof(int)* THREAD_NUM);
cudaMalloc((void**)&time, sizeof(clock_t));
cudaMemcpy(gpudata, data, sizeof(int)* DATA_SIZE, cudaMemcpyHostToDevice);
sumOfSquares << <1, THREAD_NUM, 0 >> >(gpudata, result, time);
int sum[THREAD_NUM];
clock_t time_used;
cudaMemcpy(&sum, result, sizeof(int)* THREAD_NUM, cudaMemcpyDeviceToHost);
cudaMemcpy(&time_used, time, sizeof(clock_t), cudaMemcpyDeviceToHost);
cudaFree(gpudata);
cudaFree(result);
cudaFree(time);
int final_sum = 0;
for (int i = 0; i < THREAD_NUM; i++)
final_sum += sum[i];
printf("sum: %d time: %d\n", final_sum, time_used);
final_sum = 0;
for (int i = 0; i< DATA_SIZE; i++)
sum += data[i] * data[i];
printf("sum (CPU): %d\n", final_sum);
int sum = 0;
int i;
clock_t start;
for (i = tid; i< DATA_SIZE; i += THREAD_NUM)
result[tid] = sum;
const int bid = blockIdx.x;
int sum = 0;
int i;
if (tid == 0) time[bid] = clock();
for (i = bid * THREAD_NUM + tid; i< DATA_SIZE; i += BLOCK_NUM * THREAD_NUM)
result[bid * THREAD_NUM + tid] = sum;
if (tid == 0) time[bid + BLOCK_NUM] = clock();
clock_t* time;
cudaMalloc((void**)&result, sizeof(int)* THREAD_NUM * BLOCK_NUM);
cudaMalloc((void**)&time, sizeof(clock_t)* BLOCK_NUM * 2);
sumOfSquares << <BLOCK_NUM, THREAD_NUM, 0 >> >(gpudata, result, time);
int sum[THREAD_NUM * BLOCK_NUM];
clock_t time_used[BLOCK_NUM * 2];
cudaMemcpy(&sum, result, sizeof(int)* THREAD_NUM * BLOCK_NUM, cudaMemcpyDeviceToHost);
cudaMemcpy(&time_used, time, sizeof(clock_t)* BLOCK_NUM * 2, cudaMemcpyDeviceToHost);
cudaFree(gpudata);
cudaFree(result);
cudaFree(time);
intfinal_sum = 0;
for (inti = 0; i< THREAD_NUM * BLOCK_NUM; i++)
clock_t min_start, max_end;
min_start = time_used[0];
max_end = time_used[BLOCK_NUM];
for (inti = 1; i< BLOCK_NUM; i++)
if (min_start > time_used[i])min_start = time_used[i];
if (max_end < time_used[i + BLOCK_NUM])max_end = time_used[i + BLOCK_NUM];
printf("sum: %d time: %d\n", final_sum, max_end - min_start);
extern __shared__ int shared[];
int i;
shared[tid] = 0;
shared[tid] += num[i] * num[i];
__syncthreads();
if (tid == 0)
for (i = 1; i< THREAD_NUM; i++)
shared[0] += shared[i];
result[bid] = shared[0];
clock_t* time;
cudaMalloc((void**)&result, sizeof(int)* BLOCK_NUM);
sumOfSquares << <BLOCK_NUM, THREAD_NUM, THREAD_NUM * sizeof(int) >> >(gpudata, result, time);
int sum[BLOCK_NUM];
cudaMemcpy(&sum, result, sizeof(int)* BLOCK_NUM, cudaMemcpyDeviceToHost);
cudaFree(gpudata);
cudaFree(result);
cudaFree(time);
int final_sum = 0;
for (int i = 0; i< BLOCK_NUM; i++)
__global__ static void sumOfSquares(int*num, int* result, clock_t* time)
int i;
into ffset = 1, mask = 1;
shared[tid] = 0;
__syncthreads();
while (offset < THREAD_NUM)
if ((tid& mask) == 0)
shared[tid] += shared[tid + offset];
offset += offset;
mask = offset + mask;
__syncthreads();
if (tid == 0)
offset = THREAD_NUM / 2;
while (offset > 0)
if (tid< offset)
offset >>= 1;
__syncthreads();
if (tid < 128)
shared[tid] += shared[tid + 128];
__syncthreads();
if (tid < 64)
shared[tid] += shared[tid + 64];
__syncthreads();
if (tid < 32)
shared[tid] += shared[tid + 32];
__syncthreads();
if (tid < 16)
shared[tid] += shared[tid + 16];
__syncthreads();
if (tid < 8)
shared[tid] += shared[tid + 8];
__syncthreads();
if (tid < 4)
shared[tid] += shared[tid + 4];
__syncthreads();
if (tid < 2)
shared[tid] += shared[tid + 2];
__syncthreads();
if (tid < 1)
shared[tid] += shared[tid + 1];
__syncthreads();
