How to properly include Qt library to existing makefile project in Nsight (Ubuntu)
I have a project template that just won’t work.
I have a kernel.cu file with a simple printing kernel(named bla). My main contains only these lines
#include <QImage>
#include <iostream>
extern "C" void bla();
int main() {
    QImage img("../data/brickbox1.png");
    std::cout << img.height() << std::endl;
    bla();
Compiling and everything via terminal works fine with and outputs the height of the image and a few lines from the kernel functino bla()
cd build
cmake ..
make
I now want to use Nsight IDE and created a new cuda/c++ project with an existing makefile project.
But the first line in main.cpp to include QImage always shows “unresolved include”.
First question: How do i include/setup my project, so i can use syntax helps with Qt (and dont have unresolved includes)?
Also i want to run the project (which works via command line “make” and execution of the generated file), but i just don’t know where to write what in the “Run Configuration” so i can run make and execute the programm like on command line.
Second question: How do i create a Run configuration that works and can run my project?
Hi, CuDaBuDa
We provided another nsight plugin that can installed in eclipse directly.
https://docs.nvidia.com/cuda/nsightee-plugins-install-guide/index.html
Then you can directly develop you project in eclipse and also you can use our nsight debug feature there.
Hope this help you.
