Hi there,
I have a GeForce GTX 1060 6GB that I’m using with Ubuntu 22.04. After a s/w update, I lost access to my second monitor. I eventually found the thread Nvidia Driver is not working on Ubuntu 22.04 which solved my problem, thanks generix!
In my case I’m using driver nvidia-driver-535 and running a 6.1 kernel:
$ dkms status
nvidia/535.54.03, 5.19.0-46-generic, x86_64: installed (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!)
nvidia/535.54.03, 6.1.0-1015-oem, x86_64: installed
$ uname -r
6.1.0-1015-oem
Is it safe to ignore the warnings above? My system seems to be working.
dpkg lists some old versions of libraries and drivers. Can I remove them? If so, how do I do that? sudo apt autoremove does remove them.
$ dpkg -l | grep nvidia | grep -v 535
rc linux-image-5.15.0-1028-nvidia 5.15.0-1028.28 amd64 Signed kernel image nvidia
rc linux-modules-5.15.0-1028-nvidia 5.15.0-1028.28 amd64 Linux kernel extra modules for version 5.15.0 on 64 bit x86 SMP
rc linux-modules-nvidia-530-5.19.0-42-generic 5.19.0-42.43~22.04.1 amd64 Linux kernel nvidia modules for version 5.19.0-42
rc linux-modules-nvidia-530-5.19.0-43-generic 5.19.0-43.44~22.04.1+2 amd64 Linux kernel nvidia modules for version 5.19.0-43
rc linux-modules-nvidia-530-5.19.0-45-generic 5.19.0-45.46~22.04.1 amd64 Linux kernel nvidia modules for version 5.19.0-45
rc linux-modules-nvidia-530-5.19.0-46-generic 5.19.0-46.47~22.04.1 amd64 Linux kernel nvidia modules for version 5.19.0-46
ii linux-modules-nvidia-530-generic-hwe-22.04 5.19.0-46.47~22.04.1+2 amd64 Extra drivers for nvidia-530 for the generic flavour (dummy transitional package)
rc linux-objects-nvidia-530-5.19.0-42-generic 5.19.0-42.43~22.04.1 amd64 Linux kernel nvidia modules for version 5.19.0-42 (objects)
rc linux-objects-nvidia-530-5.19.0-43-generic 5.19.0-43.44~22.04.1+2 amd64 Linux kernel nvidia modules for version 5.19.0-43 (objects)
rc linux-objects-nvidia-530-5.19.0-45-generic 5.19.0-45.46~22.04.1 amd64 Linux kernel nvidia modules for version 5.19.0-45 (objects)
rc linux-objects-nvidia-530-5.19.0-46-generic 5.19.0-46.47~22.04.1 amd64 Linux kernel nvidia modules for version 5.19.0-46 (objects)
ii linux-signatures-nvidia-5.15.0-76-lowlatency 5.15.0-76.83+2 amd64 Linux kernel signatures for nvidia modules for version 5.15.0-76-lowlatency
ii linux-signatures-nvidia-5.19.0-1028-lowlatency 5.19.0-1028.29~22.04.1+2 amd64 Linux kernel signatures for nvidia modules for version 5.19.0-1028-lowlatency
ii linux-signatures-nvidia-5.19.0-46-generic 5.19.0-46.47~22.04.1+2 amd64 Linux kernel signatures for nvidia modules for version 5.19.0-46-generic
ii linux-signatures-nvidia-6.0.0-1018-oem 6.0.0-1018.18+2 amd64 Linux kernel signatures for nvidia modules for version 6.0.0-1018-oem
ii linux-signatures-nvidia-6.1.0-1015-oem 6.1.0-1015.15+2 amd64 Linux kernel signatures for nvidia modules for version 6.1.0-1015-oem
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
Thanks,
Roger
