**• Hardware Platform: GPU A4000
**• DeepStream Version 7.1
**• NVIDIA GPU Driver Version: CUDA
I am trying to run a pipeline which is the deepstream test 1 and save the output (with the bounding boxes and so on) as an mp4 video. I changed the render node to a sink node and still it will not save properly, it’ll save as a 0 kb video which is obviously wrong.
Please choose video file output sink to replace the video render sink.
Please check and set the properties with the video file output sink extension by click the block, the properties setting tab will appear in the right side of the window. Please refer to NvDsOutputSinkExt — DeepStream documentation for the meaning of the properties.
What is the whole pipeline? How many streams will be the input of the pipeline? Will you display all objects detected or just one of them when there are several objects found by the pipeline?
the pipeline is deepstreamtest2, it is only 1 stream, I want to try both. I want to display all objects detected and also take a look at displaying just one object when there are several objects found
Since your requirement is to transfer the video content. We don’t have such sample.
DeepStream is based on GStreamer. Theoretically you can develop a GStreamer plugin with python. Writing GStreamer Plugin with Python | by Jason Kim | Medium. Perhaps you need to binding some DeepStream APIs by yourself according to your requirement. Please google by yourself.
