I have the code of JetsonHacks and it’s 1 week, i’m triing to modifed for save the video in mp4 with 2 cameraPI . Does anyone know how to do this?
import cv2
import threading
import io
import subprocess
import os.path
import shlex
import time
from multiprocessing import Queue
import sys
import numpy as np # Make sure NumPy is loaded before it is used in the callback
assert np # avoid “imported but unused” message (W0611)
gstreamer_pipeline returns a GStreamer pipeline for capturing from the CSI camera
Flip the image by setting the flip_method (most common values: 0 and 2)
display_width and display_height determine the size of each camera pane in the window on the screen
front_camera = None
back_camera = None
class CSI_Camera:
def __init__ (self) :
# Initialize instance variables
# OpenCV video capture element
self.video_capture = None
# The last captured image from the camera
self.frame = None
self.grabbed = False
# The thread where the video capture runs
self.read_thread = None
self.read_lock = threading.Lock()
self.running = False
def open(self, gstreamer_pipeline_string):
try:
self.video_capture = cv2.VideoCapture(
gstreamer_pipeline_string, cv2.CAP_GSTREAMER
except RuntimeError:
print("Unable to open camera")
print("Pipeline: " + gstreamer_pipeline_string)
return
# Grab the first frame to start the video capturing
self.grabbed, self.frame = self.video_capture.read()
def start(self):
if self.running:
print('Video capturing is already running')
return None
# create a thread to read the camera image
if self.video_capture != None:
self.running=True
self.read_thread = threading.Thread(target=self.updateCamera)
self.read_thread.start()
return self
def stop(self):
self.running=False
self.read_thread.join()
def updateCamera(self):
# This is the thread to read images from the camera
while self.running:
try:
grabbed, frame = self.video_capture.read()
with self.read_lock:
self.grabbed=grabbed
self.frame=frame
print("Could not read image from camera")
# FIX ME - stop and cleanup thread
# Something bad happened
def read(self):
frame = self.frame.copy()
grabbed=self.grabbed
return grabbed, frame
def release(self):
self.video_capture.release()
# Now kill the thread
if self.read_thread != None:
Currently there are setting frame rate on CSI Camera on Nano through gstreamer
Here we directly select sensor_mode 3 (1280x720, 59.9999 fps)
def gstreamer_pipeline(
sensor_id=0,
sensor_mode=3,
capture_width=1920,
capture_height=1080,
display_width=480,
display_height=2*720,
framerate=30,
flip_method=0,
return (
"nvarguscamerasrc sensor-id=%d sensor-mode=%d ! "
"video/x-raw(memory:NVMM), "
"width=(int)%d, height=(int)%d, "
"format=(string)NV12, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
“video/x-raw, format=(string)BGR ! appsink”
sensor_id,
sensor_mode,
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
def start_cameras():
#Parametre camera avant
front_camera = CSI_Camera()
front_camera.open(
gstreamer_pipeline(
framerate=30,
sensor_id=1,
sensor_mode=3,
capture_width=1920,
flip_method=2, #retourne l'image de 180 deg
display_height=480,
display_width=720,
front_camera.start()
#Parametre camera arrière
back_camera = CSI_Camera()
back_camera.open(
gstreamer_pipeline(
sensor_id=0,
sensor_mode=3,
capture_width=1920,
flip_method=0,
display_height=480,
display_width=720,
back_camera.start()
cv2.namedWindow("CSI Cameras", cv2.WINDOW_AUTOSIZE)
if (
not front_camera.video_capture.isOpened()
or not back_camera.video_capture.isOpened()
# Cameras did not open, or no camera attached
print("Unable to open any cameras")
# TODO: Proper Cleanup
SystemExit(0)
while cv2.getWindowProperty("CSI Cameras", 0) >= 0 :
#Lecture de la camera avant
_ , front_image=front_camera.read()
#Lecture de la camera arriere
_ , back_image=back_camera.read()
camera_images = np.hstack((front_image, back_image))
cv2.imshow("CSI Cameras", camera_images)
# This also acts as
keyCode = cv2.waitKey(30) & 0xFF
# Stop the program on the ESC key
if keyCode == 27:
break
front_camera.stop()
front_camera.release()
back_camera.stop()
back_camera.release()
cv2.destroyAllWindows()
if name == “main”:
start_cameras()
