**• Hardware Platform (Jetson / GPU)**RTX4080 • DeepStream Version7.0
In c application, we can set drop-frame-interval to adjust fps and drop frames.
In Python app, how can I set drop-frame-interval?
No what I meaned is that I can set drop-frame-interval in config file. drop-frame-interval = 2 means every 2 frames is dropped in streaming so that I can reduce fps.
How to set similar thing in python app?
def decodebin_child_added(child_proxy, Object, name, user_data):
print("Decodebin child added:", name, "\n")
if name.find("decodebin") != -1:
Object.connect("child-added", decodebin_child_added, user_data)
if not platform_info.is_integrated_gpu() and name.find("nvv4l2decoder") != -1:
# Use CUDA unified memory in the pipeline so frames can be easily accessed on CPU in Python.
# 0: NVBUF_MEM_CUDA_DEVICE, 1: NVBUF_MEM_CUDA_PINNED, 2: NVBUF_MEM_CUDA_UNIFIED
# Dont use direct macro here like NVBUF_MEM_CUDA_UNIFIED since nvv4l2decoder uses a
# different enum internally
Object.set_property("cudadec-memtype", 2)
if "source" in name:
source_element = child_proxy.get_by_name("source")
Object.set_property("drop-frame-interval", 3)
if source_element.find_property('drop-on-latency') != None:
Object.set_property("drop-on-latency", True)
Put drop-frame-interval", 3, but it doesn’t change. I am using rtsp streaming. My code is using deepstream-imagedata-multistream
I see the message as
TypeError: object of type GstRTSPSrc' does not have property drop-frame-interval’
