I have a model which has multiple outputs.
for example, outPut1 and outPut2
If I try to set these outputs using TRT python API e.g.
network.mark_output(outPut1)
network.mark_output(outPut2)
The engine gets built but results in error at runtime as
[TRT] [E] 3: [executionContext.cpp::enqueueInternal::342] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::enqueueInternal::342, condition: (mEngine.bindingIsInput(x) && hasZeroVolume(dims)) || bindings[x]
How can I set multiple outputs using TensorRT python API?
TensorRT version used: 8.4.1.5
