How to setup nano for camera input
Hi. So I have completed the initial setup. I can’t get input from my camera.
the manufacturer has the following code:
DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=3280, height=2464, format=(string)NV12, framerate=(fraction)20/1’ ! nvoverlaysink -e
when I run it, i get these errors:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 Failed to create CaptureSession
Got EOS from element “pipeline0”.
I know it regognizes the camera, since when i run
ls /dev/video*, it returns video0
I tried using a different sink, and I installed the updates with this:
sudo apt update
sudo apt install gstreamer1.0-tools gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
the code uses an HDMI LCD display, but I want to use my computer to display this, so thats already the first issue. The second issue is a need for another interface. Apparently, I need a graphical interface, not a ubuntu text interface. How can this be done?
Can someone guide me in installing the libraries,interface, and dependencies to have this work? I am new to this and my goal is to learn opencv and c++ with the nano.
What’s your camera?
v4l2-ctl --all
Its a stereo camera called the IMX210-83 Stereo Camera, with two IMX219’s joined together. I think they are treated as different cameras. The link below is the setup and info page. The example in the link uses an LCD display for output, but I want it to display on my computer.
Confirm below command due to nvoverlaysink was deprecated.
And for preview on your host, please check the RTSP via network.
DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=3280, height=2464, format=(string)NV12, framerate=(fraction)20/1' ! nvvidconv ! xvimagesink sync=false
How can I do that? Please guide me on RTSP, and what I should do to get it running.
Please search the RTSP in this forum to get much detail information.
