I am using UYVY camera sensor and able to stream perfectly in Xavier but some time anything wrong happens in my sensor side then I am not able to stop application and kernel crashes. The only way to recover again by the reboot.
[ 1284.506478] ------------[ cut here ]------------
[ 1284.510977] WARNING: CPU: 2 PID: 8668 at /home/ritesh/PROJECT/kernel/kernel-4.9/drivers/media/v4l2-core/videobuf2-core.c:899 vb2_buffer_done+0x1f0/0x230
[ 1284.527847] Modules linked in: bnep fuse nvs_bmi160 nvs ar1335(O) pwm_pca9685 bluedroid_pm ip_tables x_tables
[ 1284.527891] CPU: 2 PID: 8668 Comm: vi-output, ar13 Tainted: G W O 4.9.108-g696b0c1 #61
[ 1284.527894] Hardware name: jetson-xavier (DT)
[ 1284.527898] task: ffffffc3e9234600 task.stack: ffffffc349400000
[ 1284.527911] PC is at vb2_buffer_done+0x1f0/0x230
[ 1284.527916] LR is at free_ring_buffers+0x6c/0x138
[ 1284.527919] pc : [] lr : [] pstate: 20c00045
[ 1284.527920] sp : ffffffc349403d00
[ 1284.527922] x29: ffffffc349403d00 x28: 0000000000000002
[ 1284.527925] x27: 0000000000000000 x26: ffffffc3d681beb8
[ 1284.527928] x25: ffffff8009e87000 x24: 431bde82d7b634db
[ 1284.527930] x23: 0000000000000007 x22: ffffffc3d681bb48
[ 1284.527933] x21: ffffffc3b123b400 x20: ffffffc3b123b400
[ 1284.527935] x19: ffffffc3d681b018 x18: 0000000000000010
[ 1284.527937] x17: 0000007fab76ef60 x16: 0000000000000001
[ 1284.527940] x15: 0000000000002f06 x14: 0000000000000000
[ 1284.527942] x13: 0000000000000000 x12: 0000000000002552
[ 1284.527944] x11: 0000000000000400 x10: 000000000004fda8
[ 1284.527946] x9 : 0000000000000313 x8 : 000000000000021a
[ 1284.527949] x7 : 0000000000000000 x6 : 0000000000000000
[ 1284.527951] x5 : fffffffffffffff0 x4 : ffffffc3d681bd00
[ 1284.527954] x3 : 0000000000000003 x2 : ffffffc39fd76818
[ 1284.527956] x1 : 0000000000000007 x0 : 0000000000000007
[ 1284.527960] —[ end trace 1dcac0298b5ebd3f ]—
[ 1284.532306] Call trace:
[ 1284.532316] [] vb2_buffer_done+0x1f0/0x230
[ 1284.532320] [] free_ring_buffers+0x6c/0x138
[ 1284.532326] [] tegra_channel_kthread_capture_dequeue+0x184/0x390
[ 1284.532334] [] kthread+0xe8/0x100
[ 1284.532342] [] ret_from_fork+0x10/0x50
NOTE:- Above crash continuously coming and if I leave Xavier board after the crash then complete Xavier memory full.
I checked above crash is because of free_ring_buffers called in case of the negative value of chan->num_buffers then I tried to fix this with some change in tegra_channel_capture_dequeue function.
if (chan->num_buffers >= (chan->capture_queue_depth - 1)) {
chan->buffer_state[chan->free_index] = buf->vb2_state;
free_ring_buffers(chan, 1);
After above line added in tegra_channel_capture_dequeue then above kernel crash not happening and able to stop the application.
But now I am getting the new kernel crash.
[ 1902.374303] WARNING: CPU: 2 PID: 8632 at /home/ritesh/PROJECT/kernel/kernel-4.9/drivers/media/v4l2-core/videobuf2-core.c:1659 __vb2_queue_cancel+0x114/0x170
[ 1902.374589] Modules linked in: bnep fuse nvs_bmi160 nvs ar1335(O) pwm_pca9685 bluedroid_pm ip_tables x_tables
[ 1902.374644] CPU: 2 PID: 8632 Comm: multicam.elf Tainted: G W O 4.9.108-g696b0c1 #88
[ 1902.374653] Hardware name: jetson-xavier (DT)
[ 1902.374658] task: ffffffc397b18000 task.stack: ffffffc3693d8000
[ 1902.374663] PC is at __vb2_queue_cancel+0x114/0x170
[ 1902.374667] LR is at __vb2_queue_cancel+0x3c/0x170
[ 1902.374670] pc : [] lr : [] pstate: 80400045
[ 1902.374672] sp : ffffffc3693dbae0
[ 1902.374675] x29: ffffffc3693dbae0 x28: 0000000000000009
[ 1902.374681] x27: 0000007f6d0871f0 x26: ffffffc3af52bb80
[ 1902.374687] x25: ffffffc369211710 x24: 0000000000000001
[ 1902.374696] x23: ffffffc3b5c30048 x22: ffffffc3d7d7cb48
[ 1902.374702] x21: ffffffc3d7d7c030 x20: ffffffc3d7d7cba8
[ 1902.374707] x19: ffffffc3d7d7cb48 x18: 0000000000000000
[ 1902.374712] x17: 0000007f8fdf2a78 x16: 000000000000d45e
[ 1902.374717] x15: ffffff800a16e2c0 x14: 2065736e6f707365
[ 1902.374722] x13: 0000000000000000 x12: 071c71c71c71c71c
[ 1902.374727] x11: 000000000000000b x10: 00000000000009d0
[ 1902.374732] x9 : ffffffc3693d8000 x8 : ffffffc397b18a30
[ 1902.374741] x7 : fefefeff646c606d x6 : 0000000000000000
[ 1902.374746] x5 : fffffffffffffffc x4 : 0000000000000040
[ 1902.374751] x3 : 0000000000000001 x2 : 0000000000000000
[ 1902.374756] x1 : 0000000000000001 x0 : 0000000000000004
[ 1902.374763] —[ end trace 9c12d2f948c860f4 ]—
[ 1902.374852] Call trace:
[ 1902.374860] [] __vb2_queue_cancel+0x114/0x170
[ 1902.374866] [] vb2_core_queue_release+0x2c/0x58
[ 1902.374875] [] _vb2_fop_release+0x88/0xa8
[ 1902.374881] [] tegra_channel_close+0x58/0x120
[ 1902.374886] [] v4l2_release+0x48/0xa0
[ 1902.374893] [] __fput+0x94/0x1d0
[ 1902.374897] [] ____fput+0x20/0x30
[ 1902.374905] [] task_work_run+0xc0/0xe0
[ 1902.374912] [] do_exit+0x2d4/0xa18
[ 1902.374917] [] do_group_exit+0x40/0xa8
[ 1902.374924] [] get_signal+0x3d8/0x5c8
[ 1902.374931] [] do_signal+0x17c/0x4f8
[ 1902.374940] [] do_notify_resume+0x98/0xb8
[ 1902.374945] [] work_pending+0x8/0x10
So, Can anyone suggest me solution for the 2nd crash if first applied fix is fine?
