Hi guys,
I want to use multi-stream decoder using harware of jetson nano in opencv’s VideoCapture+Gstreamer1.0. I use the below codes for that processing.
You may want to try with the ‘nvvidconv’ plugin which can be used as a replacement with hardware optimization for videoconvert. However, as you are using appsink you may want to check the following topic
For instructions on how to use the nvvidconv with appsink.
