How to start triton server after building the tritonserver Image for custom windows server 2019?
Building the windows-based triton server image.
Building the Dockerfile.win10.min for triton server version 22.11 was not working as base image required for building the server image was not available for downloading.
To build the image downgraded the triton server version to 22.10. Also needed to download the appropriate CUDNN and TENSORT version for building the image.
Successfully built the base image using below command for 22.10 server version.
docker build -t win10-py3-min -f Dockerfile.win10.min .
Once base image is built. To build the triton server image used below command with appropriate container tag and required backend.
python build.py --cmake-dir=<path/to/repo>/build --build-dir=/tmp/citritonbuild --no-container-pull --image=base,win10-py3-min --enable-logging --enable-stats --enable-tracing --enable-gpu --endpoint=grpc --endpoint=http --repo-tag=common: --repo-tag=core: --repo-tag=backend: --repo-tag=thirdparty: --backend=ensemble --backend=tensorrt: --backend=onnxruntime: --backend=openvino:
Tried different arguments with build.py command to build the triton server image was unsuccessful. As there were certain issues related to CMAKE, Rapid Json.
Certain issues on github suggested to try with the latest stable release which is 22.12. For building the base image it required the same os as per 22.11. So, to build the base image used the Dockerfile.win10.min file from 22.10 version which worked earlier.
After passing different arguments to build.py file was able to build the tritonserver image. However, initially built images did not have the tritonserver.exe which is required for starting the server. In the end was able to build the tritonserver which had the required tritonserver.exe.
built the image using below command.
python build.py -v --no-container-pull --image=base,win10-py3-min --enable-logging --enable-stats --enable-tracing --enable-gpu --endpoint=grpc --endpoint=http --repo-tag=common:r22.12 --repo-tag=core:r22.12 --repo-tag=backend:r22.12 --repo-tag=thirdparty:r22.12 --backend=ensemble
To start the triton server, need to mount the local model repository to the docker image. Command to start the server is as below.
docker run -it -v C:/Users/Desktop/model_repository:C:/opt/tritonserver/models tritonserver:latest bin/tritonserver.exe --model-repository=C/opt/tritonserver/models
While starting the triton server getting the below error.
failed to resize tty, using default size
We recommend you to raise this query in TRITON Inference Server Github instance issues section.
Hi @NVES ,
I’m having the same issue, I believe Triton is an NVIDIA product for deployment and it should at least support all the deployment-level OS. So can you please provide reference steps to solve this issue?
Could you please checkout the following.
You can also try Triton Inference Server | NVIDIA NGC.
If you need further assistance, please reach out to Issues · triton-inference-server/server · GitHub to get better help.
Thank you.
