Hi, all
I use CUDA for several month.
In my program, double precision is critical.
On cuda2.0, I added a compiler command <-arch compute_13>, and double precision is well supported.
The following is my compiling command
[codebox]"(CUDA_BIN_PATH)\nvcc.exe" -arch compute_13 -ccbin "(VCInstallDir)bin" -c -DWIN32 -D_CONSOLE -D_MBCS -Xcompiler /EHsc,/W3,/nologo,/Wp64,/O2,/Zi,/MT -I"(CUDA_INC_PATH)" -I./ -I"(NVSDKCUDA_ROOT)\common\inc" -o $(ConfigurationName)$(InputName).obj .\CUDA$(InputFileName)
[/codebox]
But unfortunately, after I upgrade CUDA to 2.1, I open this project with Visual Studio2005, build and run the project, double precision is not supported any more.
I try to build and run some other projects which only use single precision float, everything is OK.
After that, I try to modify the compiling command to be "-arch compute_13 - code sm_13 " and “-arch sm_13” and some others, none of them works fine.
My CUDA toolkit2.1 , SDK2.1 and driver 181.20 is downloaded directly from
http://www.nvidia.com/object/cuda_get.html
My graphic card is GTX280, OS is WindowsXP Sp2
Can anyone tell me what the problem is?
Or how to support double precision on CUDA2.1?
Is it a bug of CUDA2.1?
Thanks in advance for your help.
