Jetpack 4.6 comes pre installed with Open CV 4.1.1
Which doesn’t support Open CV DNN module and I am unable to uninstall the pre installed version of Open CV.
How can I use another version of Open CV ?
You can build one with the script below:
For this first we need to remove the pre installed open cv
Right ?
If you link the library properly, it’s possible to have two different libraries at the same time.
But you can remove it to avoid any possible compatibility issues.
$ sudo apt-get purge *libopencv*
