I have the following code
int main(int argc, char** argv )
std::vector< std::vector< std::vector<double> > > vec {
{{1,2},{3,4}, {5,6},{7,8}},
{{9,10}, {11,12}},
{{13,14}, {15,16}, {17,18}} };
#pragma acc parallel loop
for (int k = 0; k <3; k++) {
std::vector<std::vector<double>>& vec2d = vec[k];
int L = vec2d.size();
//std::vector<int>dVec{67,51,1,0,50};
std::vector<double>dVec(L, 0.0);
for (int i = 0; i < L; i++)
dVec[i] = vec2d[i][1] - vec2d[i][0];
for (int j=0; j<2; j++) {
printf("k: %d j: %d vec0: %f, vec1: %f\n", k, j, vec2d[j][0], vec2d[j][1]);
std::cout<<"finished\n";
return 0;
and I compile with pgc++ -fast -ta=tesla:cuda9.2,managed -o runEx runEx.cpp -std=c++17 && ./runEx
if I comment out the #pragma acc parallel loop, then it works. But if I leave it there, then I get the error
PGCC-S-0155-Procedures called in a compute region must have acc routine information: operator delete (void *) (runEx.cpp: 425)
PGCC-S-0155-Accelerator region ignored; see -Minfo messages (runEx.cpp: 6)
PGCC/x86-64 Linux 19.10-0: compilation completed with severe errors
Also, if I comment out the std::vector<int>dVec and the for loop containing it, then the code works even with the #pragma acc parallel loop
However, if I change the loop so it becomes just:
then I get the same error
why is this?
