I have converted my model to onnx format and then converted that to .trt
now i want to use that for inference how can I use it for the inference on jetson nano? please guide
Thank You
Thank You
Please noticed that TensorRT engine is not portable.
So you will need to generate the file directly on the Jetson Nano.
Here is the code sample for running a serialized file:
nvinfer1::ICudaEngine* engine = infer->deserializeCudaEngine(engine_stream, engine_size);
nvinfer1::IExecutionContext* context = engine->createExecutionContext();
context->enqueue(1, mBindings, mStream, NULL);
You can find more details in our /usr/src/tensorrt/samples/sampleUffFasterRCNN sample.
Thank you,
I have used onnx2trt on the jetson nano itself to generate .trt.
I was able to load .trt engine, but now I want to make inference with it but not getting how ?
import os
import tensorrt as trt
def load_engine(trt_runtime, engine_path):
with open(engine_path, ‘rb’) as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_runtime = trt.Runtime(TRT_LOGGER)
trt_engine_path = “engine.trt”
trt_engine = load_engine(trt_runtime, trt_engine_path)
if trt_engine is not None:
print(“Success”)
else:
print(“Failed”)
Result : Success
but how to go further for inference?
trained model is of object detection
please guide
You can find a detection example in the following path:
/usr/src/tensorrt/samples/python/uff_ssd/detect_objects.py
