I am currently using YoloV3 with nvdsinfer_custom_impl_Yolo. I would now like to use YoloV4 and convert my .cfg and .weights files within deepstream. However, I get the error “Yolo type is not defined from config file name”. How can I use yolov4? There is also no yolov4 in the samples.
Are your pipelines for yolov3 and yolov4 the same?
Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) GLib, Gst, GstRtspServer, GObject
Here is a similar post from me. However, this time it is a different bug with yolov4. I think it might have something to do with nvdsinfer_custom_impl_yolo though.
I tested your suggestion with this github repository:
1.Please provide complete information as applicable to your setup.
• TensorRT Version
2.How do you get the fps?
3.Could you use both our model to test it? deepstream_tao_apps This project have both our yolov3, yolov4 model.
