As the title, I have a desktop and want to use iGPU for display and GTX 960 only for CUDA.
I know someone says this can be done by delete “Device” about Nvidia from xorg.conf and explicitly add BusID to “Device” under intel iGPU.
However, after I reboot, I meet a login loop, which means X window brings me back to the login window after I enter my password.
I went to tty1 and restart the lightdm service. It stops at loading extension GLX. I checked Xorg.0.log, it shows that when it tried to load GLX, it use /usr/lib/xorg//modules/extensions/libglx.so. However, this “libglx.so” is a link to “libglx.so.352.21”, which is from the NVIDIA 352.21 driver. So this means that X window tries to use Nvidia file for glx anyway because NVIDIA driver made a link to libglx.so.
The only way I can find to use iGPU for display is to uninstall NVIDIA driver. And then reinstall libglx.so (from a package about libg11 or something, I forget). But I can not use CUDA without NVIDIA driver.
To summary, install NVIDIA driver will delete former libglx.so (actually, also many other statics libraries like libGL.so.1 …). If I use Nvidia GTX 960 for display and cuda, it works fine. But, if I change the BIOS and xorg.conf to use intel iGPU for display, it tries to use Nvidia’s libglx.so.352.21, which leads me to a login loop. To use intel iGPU for display, I need get my previous statics libraries back which drives me crazy.
I wonder whether someone here can help me and tell me how to use intel iGPU for display and GTX 960 for CUDA only, considering my situations above.
To summary their solution, first they install Nvidia driver and then reinstall mesa and some other packages. But in my case, I still get errors when load GLX, some errors related to *-tls.so *-glcore.so.
The way I solve this situation is to uninstall Nvidia diver 352.21. Reinstall mesa and other packages. Then use CUDA-7.0.run to install Nvidia driver 346.46, which comes with this .run file. And I also choose not to install Nvidia’s OpenGL. Then I can login in X window fine with iGPU for display.
But as Nvidia driver does not work on X server. I get many N/A from nvidia-smi. Also nvidia-setting does not work as they require Nvidia driver works on X. But anyway, I can use my GTX 960 for heavy work without disturbing my display.
I find one solution for my laptop (HD4000 + NV860M), I hope it will help you.
When I have installed Ubuntu, I have a device i915 for Intel and nouveau for Nvidia. The primary display is on the Intel Graphics. Then I have blocked the nouveau device according to the Cuda tutorial ([url]http://docs.nvidia.com/cuda/cuda-getting-started-guide-for-linux/[/url]) by installing with the runfile. Make sure to use –no-opengl-libs so your previous display settings are not overwritten. After that, you should have Intel for display and Nvidia for Cuda.
I am not sure that works on desktop, but hope you can find you way out soon.
