Https://pypi.jetson-ai-lab.dev/jp6/cu126 has been inaccessible for over 72 hours
Hello everyone - I’ve been working through the various demos for Jetson Orin Nano Super Dev Kit. I have run into an issue with accessing : https://pypi.jetson-ai-lab.dev/jp6/cu126 When running commands inside the nanoowl container, such as “pip install aiohttp” it seems that the index has been unreachable for at least the last 72 hours. This fails inside Docker container or on the Jetson Nano itself. Can anyone advise if this is a known outage or issue?
Looking in indexes: https://pypi.jetson-ai-lab.dev/jp6/cu126
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb2e8ff40>: Failed to establish a new connection: [Errno 113] No route to host’)': /jp6/cu126/pip/
I’m confirming with the team to see if any ETA to get it back. Thanks
Thank you!
Ok, it’s now been over a week.
Are there any news about the service? It’s almost impossible to build containers for the Jetson Orin NX without this repository. 😔
pypi.jetson-ai-lab.dev is down. We are improving security and performance. Meanwhile please use pypi.jetson-ai-lab.io by setting the enviroment variable INDEX_HOST=jetson-ai-lab.io in .env file.
You can also refer to Jetson-ai-lab server down? - Jetson & Embedded Systems / Jetson Orin Nano - NVIDIA Developer Forums
So is pypi.jetson-ai-lab.io now down as well?
Can’t reach it as of this morning.
Is the service still down? I tried with pypi.jetson-ai-lab.io and pypi.jetson-ai-lab.dev
.io is back up, at least as of right now.
For backup reason I made a simple python script to download all of them at least in jp6 and jp7 packages
I hope that helps other If something happen. I hope that resolve as well.
So .io is back up, but I guess (as others have mentioned) it’s missing stuff.
During build, I get
Installing NVIDIA Video Codec SDK 13.0.19 (NVENC/CUVID)
  • cd /tmp/video-codec-sdk
  • ‘[’ ‘!’ -f Video_Codec_SDK_13.0.19.zip ‘]’
  • wget --quiet --show-progress --progress=bar:force:noscroll --no-check-certificate https://apt.jetson-ai-lab.io/multiarch/Video_Codec_SDK_13.0.19.
    zip
    The command ‘/bin/sh -c $TMP/build.sh || $TMP/install.sh’ returned a non-zero code: 8
The wget of Video_Codec_SDK_13.0.19.zip fails. It doesn’t exist at the specified location.
Any ETA on when .dev will be back up?
Hi, all
The repo owner has stepped down, but we try to keep most of the resources available to minimize the impact.
The URL has been changed to https://pypi.jetson-ai-lab.io/.
You can follow the update on jetson-container to get the latest info:
Thank you.
Is the .io version of the site an exact replica of the .dev version? I’ve run into a problem where the jetson-build process can’t find a specific file: https://apt.jetson-ai-lab.io/multiarch/Video_Codec_SDK_13.0.19 (I’m not sure how apt.jetson-ai-lab.io relates to pypi.jetson-ai-lab.io).
The package is in the multiarch but there is no multiarch support in https://pypi.jetson-ai-lab.io.
Only Jetpack 6.2 (CUDA 12.6) and JetPack 7 (CUDA 13.x) are supported now.
But the Video Codec source file (.zip) can be found on the website directly:
Thank you for the link.
So once I downloaded the video codec from that site, how would make the jetson-containers build process use that downloaded version instead of where it’s currently trying to get it (https://apt.jetson-ai-lab.io/multiarch)?
FWIW: I ended up downloading the Video Codec SDK .zip file and placed it in jetson-containers/packages/multimedia/video-code-sdk. I also modified install.sh in that folder so that variable “ZIP” pointed to the downloaded file (“./Video_Codec_SDK_13.0.0.19.zip”) and commented out the wget code that was trying to download it.
Thanks again for the pointer to the link.
Thank you for the feedback as well.
Well, the https://pypi.jetson-ai-lab.io/ server is now down as well.
Help, the https://pypi.jetson-ai-lab.io/ server is now down as well.
Both .io and .dev are down for me. Was this a single point of failure? One person and one person only in controller of all of jetson py package distribution?
