Huge instruction stream for reciprocal on CC 2.0 reciprocal operation side effect?
I have written this trivial kernel:
__global__ void ktestRecipr(float *buffer, int terms){
	int term_m_1 = blockIdx.x * blockDim.x + threadIdx.x;
	float term_dbl = 2.0f*(float)term_m_1;
	buffer[term_m_1] = 1.0f/(1.0f+term_dbl);
The problem is that for CC 2.0 it translates to a huge stream of instructions, where for CC1.1 the instruction stream is normal (short). Thus code for CC 2.0 is not efficient and I don’t know what causes it. It seems as a fault of the reciprocal operation as removing it turns the instruction stream to a very short one (i.e. buffer[term_m_1] = 1.0f+term_dbl; )
The instruction stream as of cuobjbin output is:
Function : _Z11ktestReciprPfi
	/*0000*/     /*0x00005de428004404*/ 	MOV R1, c [0x1] [0x100];
	/*0008*/     /*0x94001c042c000000*/ 	S2R R0, SR_CTAid_X;
	/*0010*/     /*0x84009c042c000000*/ 	S2R R2, SR_Tid_X;
	/*0018*/     /*0x20001c0320044000*/ 	IMAD.U32.U32 R0, R0, c [0x0] [0x8], R2;
	/*0020*/     /*0x01209e0418000000*/ 	I2F.F32.S32 R2, R0;
	/*0028*/     /*0x08209c0050000000*/ 	FADD R2, R2, R2;
	/*0030*/     /*0x00211c005000cfe0*/ 	FADD R4, R2, 0x3f800;
	/*0038*/     /*0x6001000750000000*/ 	CAL 0x58;
	/*0040*/     /*0x80001c4340004000*/ 	ISCADD R0, R0, c [0x0] [0x20], 0x2;
	/*0048*/     /*0x00011c8590000000*/ 	ST [R0], R4;
	/*0050*/     /*0x00001de780000000*/ 	EXIT;
	/*0058*/     /*0x04409c036000c000*/ 	SHL.W R2, R4, 0x1;
	/*0060*/     /*0x60209c035800c000*/ 	SHR.U32.W R2, R2, 0x18;
	/*0068*/     /*0x0c20dc034800c000*/ 	IADD R3, R2, 0x3;
	/*0070*/     /*0x0c20dc041c000000*/ 	I2I.U32.U8 R3, R3;
	/*0078*/     /*0x0c31dc03198ec000*/ 	ISETP.LE.U32.AND P0, pt, R3, 0x3, pt;
	/*0080*/     /*0x800001e740000000*/ 	@P0 BRA 0xa8;
	/*0088*/     /*0x10409c00c8000000*/ 	MUFU.RCP R2, R4;
	/*0090*/     /*0x0440dc0030048000*/ 	FFMA R3, R4, R2, c [0x10] [0x0];
	/*0098*/     /*0x0c211e0030040000*/ 	FFMA R4, R2, -R3, R2;
	/*00a0*/     /*0x60001de740000007*/ 	BRA 0x280;
	/*00a8*/     /*0xfc21dc031a8e0000*/ 	ISETP.NE.U32.AND P0, pt, R2, RZ, pt;
	/*00b0*/     /*0x000001e740000003*/ 	@P0 BRA 0x178;
	/*00b8*/     /*0xfc409c023801ffff*/ 	LOP32I.AND R2, R4, 0x7fffff;
	/*00c0*/     /*0x0800dc0378000000*/ 	FLO.U32 R3, R2;
	/*00c8*/     /*0x7c30de034800c000*/ 	IADD R3, -R3, 0x1f;
	/*00d0*/     /*0xdc315c034800ffff*/ 	IADD R5, R3, 0xffff7;
	/*00d8*/     /*0x0451dc03198ec000*/ 	ISETP.LE.U32.AND P0, pt, R5, 0x1, pt;
	/*00e0*/     /*0x400001e740000000*/ 	@P0 BRA 0xf8;
	/*00e8*/     /*0x10411c00c8000000*/ 	MUFU.RCP R4, R4;
	/*00f0*/     /*0x20001de740000006*/ 	BRA 0x280;
	/*00f8*/     /*0xe0315c034800ffff*/ 	IADD R5, R3, 0xffff8;
	/*0100*/     /*0x14209c0360000000*/ 	SHL.W R2, R2, R5;
	/*0108*/     /*0xfc209c023801ffff*/ 	LOP32I.AND R2, R2, 0x7fffff;
	/*0110*/     /*0x00209c4238fe0000*/ 	LOP32I.OR R2, R2, 0x3f800000;
	/*0118*/     /*0x10215c00c8000000*/ 	MUFU.RCP R5, R2;
	/*0120*/     /*0x04209c00300a8000*/ 	FFMA R2, R2, R5, c [0x10] [0x0];
	/*0128*/     /*0x08509e00300a0000*/ 	FFMA R2, R5, -R2, R5;
	/*0130*/     /*0xfc209c023801ffff*/ 	LOP32I.AND R2, R2, 0x7fffff;
	/*0138*/     /*0xfc215c03110e0000*/ 	ISET.EQ.U32.AND R5, R2, RZ, pt;
	/*0140*/     /*0x1430dd0348000000*/ 	IADD R3, R3, -R5;
	/*0148*/     /*0xd0315c034800c003*/ 	IADD R5, R3, 0xf4;
	/*0150*/     /*0x0040dc023a000000*/ 	LOP32I.AND R3, R4, -0x80000000;
	/*0158*/     /*0x5c511c036000c000*/ 	SHL.W R4, R5, 0x17;
	/*0160*/     /*0x1030dc4368000000*/ 	LOP.OR R3, R3, R4;
	/*0168*/     /*0x0c211c4368000000*/ 	LOP.OR R4, R2, R3;
	/*0170*/     /*0x20001de740000004*/ 	BRA 0x280;
	/*0178*/     /*0x0c215c034800fffc*/ 	IADD R5, R2, 0xfff03;
	/*0180*/     /*0x0451dc031a0ec000*/ 	ISETP.GT.U32.AND P0, pt, R5, 0x1, pt;
	/*0188*/     /*0xa00001e740000003*/ 	@P0 BRA 0x278;
	/*0190*/     /*0xfc40dc023801ffff*/ 	LOP32I.AND R3, R4, 0x7fffff;
	/*0198*/     /*0x0c029de218000000*/ 	MOV32I R10, 0x3;
	/*01a0*/     /*0x00411c023a000000*/ 	LOP32I.AND R4, R4, -0x80000000;
	/*01a8*/     /*0x00319c4238fe0000*/ 	LOP32I.OR R6, R3, 0x3f800000;
	/*01b0*/     /*0x14a29c0360000000*/ 	SHL.W R10, R10, R5;
	/*01b8*/     /*0x1061dc00c8000000*/ 	MUFU.RCP R7, R6;
	/*01c0*/     /*0x04619c00300e8000*/ 	FFMA R6, R6, R7, c [0x10] [0x0];
	/*01c8*/     /*0x18721e00308e0000*/ 	FFMA.RM R8, R7, -R6, R7;
	/*01d0*/     /*0x18719e00310e0000*/ 	FFMA.RP R6, R7, -R6, R7;
	/*01d8*/     /*0xfc825c023801ffff*/ 	LOP32I.AND R9, R8, 0x7fffff;
	/*01e0*/     /*0x1881dc002e8e0000*/ 	FSETP.NEU.FTZ.AND P0, pt, R8, R6, pt;
	/*01e8*/     /*0x00925c4238020000*/ 	LOP32I.OR R9, R9, 0x800000;
	/*01f0*/     /*0x07f1dc042010c000*/ 	SEL R7, RZ, 0x1, !P0;
	/*01f8*/     /*0x24a29c0368000000*/ 	LOP.AND R10, R10, R9;
	/*0200*/     /*0x14a19c0358000000*/ 	SHR.U32.W R6, R10, R5;
	/*0208*/     /*0x24515c0368000000*/ 	LOP.AND R5, R5, R9;
	/*0210*/     /*0x08621c036800c000*/ 	LOP.AND R8, R6, 0x2;
	/*0218*/     /*0x14715c4368000000*/ 	LOP.OR R5, R7, R5;
	/*0220*/     /*0x1021dc034800fffc*/ 	IADD R7, R2, 0xfff04;
	/*0228*/     /*0xfc81dc031a8e0000*/ 	ISETP.NE.U32.AND P0, pt, R8, RZ, pt;
	/*0230*/     /*0x04609c036800c000*/ 	LOP.AND R2, R6, 0x1;
	/*0238*/     /*0xfc51dc031aa00000*/ 	ISETP.NE.U32.OR P0, pt, R5, RZ, P0;
	/*0240*/     /*0x1c915c0358000000*/ 	SHR.U32.W R5, R9, R7;
	/*0248*/     /*0xfc21dc231a800000*/ 	ISETP.NE.AND P0, pt, R2, RZ, P0;
	/*0250*/     /*0x045140034800c000*/ 	@P0 IADD R5, R5, 0x1;
	/*0258*/     /*0x04509c036000c000*/ 	SHL.W R2, R5, 0x1;
	/*0260*/     /*0x14209c0331060000*/ 	ICMP.EQ.U32 R2, R2, R5, R3;
	/*0268*/     /*0x10211c4368000000*/ 	LOP.OR R4, R2, R4;
	/*0270*/     /*0x20001de740000000*/ 	BRA 0x280;
	/*0278*/     /*0x10411c00c8000000*/ 	MUFU.RCP R4, R4;
	/*0280*/     /*0x00001de790000000*/ 	RET;
The CC 1.1 instruction stream is:
	/*0000*/     /*0x1000020540004780*/ 	G2R.U16 R0H, g [0x1].U16;
	/*0008*/     /*0xa000000504000780*/ 	I2I.U32.U16 R1, R0L;
	/*0010*/     /*0x60014c0100204780*/ 	IMAD.U16 R0, g [0x6].U16, R0H, R1;
	/*0018*/     /*0xa000000544014780*/ 	I2F.F32.S32 R1, R0;
	/*0020*/     /*0xb000020500004780*/ 	FADD R1, R1, R1;
	/*0028*/     /*0x30020001c4100780*/ 	SHL R0, R0, 0x2;
	/*0030*/     /*0xb000020503f80003*/ 	FADD32I R1, R1, 0x3f800000;
	/*0038*/     /*0x2100e800        */ 	IADD32 R0, g [0x4], R0;
	/*003c*/     /*0x90000204        */ 	RCP32 R1, R1;
	/*0040*/     /*0xd00e0005a0c00781*/ 	GST.U32 global14 [R0], R1;
Seems weird…
Check code generated with -use_fast_math. Compute capability 1.1 isn’t fully IEEE 754-compliant either, so that would would be a comparison on equal grounds.
If you look a little deeper at the generated code, you can see that there are many paths that jump over a significant number of lines. So actual number of instructions executed is going to be less than the pure number of lines of generated code. For example the bra 0x280 instructions are effectively return statements.
For compute capability 1.x, the single precision division operator ‘/’ and the sqrtf() function are translated into fast but approximate division, reciprocal, and square root implementations. The only way to get at implementations rounded according to IEEE-754 rounding rules is via device functions (intrinsics): __frcp_rn(), __fdiv_rn(), __fsqrt_rn().
For compute capability 2.x, the single precision division operator ‘/’ and the sqrtf() function are mapped to IEEE rounded division, reciprocal, and square root implementations by default. Programmers can override this default on a per-compilation-unit basis, by using the following compiler switches:
-prec-div={true|false} if false, use approximate single-precision reciprocal and division
-prec-sqrt={true|false} if false, use approximate single-precision square root
The compiler flag -use_fast_math mentioned by tera implies -ftz=true -prec-div=false -prec-sqrt=false, but in addition causes additional functions like cosf(), sinf(), expf(), logf() to be mapped to faster implementation with (on average) larger approximation error, so if your concern is only about the reciprocal, I would recommend using the finer grained control afforded by -prec-div.
As far as the code for the IEEE-compliant single-precision reciprocal, division, and square root is concerned, please note that not the entire code shown in the disassembly listing is executed for every operation / function invocation. For the vast majority of arguments the code goes through a “fast path” consisting of relatively few instructions. Only for difficult corner cases does it go through a more elaborate “slow path” which is invoked conditionally.
Thank you. This was very explanatory.
May I ask what those “difficult corner cases” are, and how often they could be encountered? Thanks!
Difficult cases are those involving operands close to the end of the exponent range, so numbers either very small or very large in magnitude. In addition, operands that are NaNs. How frequently any piece of code will invoke the slow path thus depends on the specific mix of input operands. In general, “normal” applications tend to hit the slow path so infrequently that it does not have a performance impact.
This is the way I came around this problem,
I couldn’t get -prec-sqrt=true to work, so I went for this algorythm : Babylonian method, Square root algorithms - Wikipedia
this works like this:
for calculating square root of S:
x_0 = initial guess;
x[sub]n+1[/sub] = 1/2.0 * ( x[sub]n[/sub] + S / x[sub]n[/sub] );
as for my initial guess I chose sqrtf() from cuda!!
for example below sqrt(1234567891) is calculated:
double x_n;
x_n=sqrtf(1234567891);
double s=1234567891;
for (int tt=1;tt<10;++tt){
x_n=1.0/2.0*(x_n+s/x_n);
this is the results:
Matlab on CPU:
3.513641830067487e+004
Babylonian method above with GPU:
3.5136418300674872e+004
Cuda sqrtf:
3.513641796875e+004
as you can see above method reaches great resluts to be compared with cpu in very low number of iterations!! while sqrtf is really off!!!
( I haven’t tried optimizing that tt=10 number of iterations!!)
It looks like you are trying to do a computation using doubles, yet you are using the single precision square root function.
The function prototypes are something like:
float sqrtf(float)
double sqrt(double)
Basically, try using sqrt instead of sqrtf. You should then get your accuracy in one function call instead of needing to use Newton’s method.
