I installed the ‘omniverse composer’ on my server computer.
And I installed ‘livestream native backend’ extention.
However, the client cannot connect to the server. (streaming client App)
I attached ‘kit-remote.log’ file. (below)
Please help me :)
[2024-05-27 02:21:56,325]=11:21:56= DEBUG [Geronimo: GeronimoRemoteConfig] {00003F60} - Cannot open config file RemoteConfig.json.
[2024-05-27 02:21:56,326]=11:21:56= INFO [Tracing] {00003F60} - Starting tracing for gfn-gamestream.
[2024-05-27 02:21:56,326]=11:21:56= ERROR [OV-Streaming-Client: main] {00003F60} - SetProcessDpiAwareness failed with 80070005
[2024-05-27 02:21:56,326]=11:21:56= INFO [OV-Streaming-Client: main] {00003F60} - Command line: “kit-remote.exe --width 1920 --height 1080 --server 172.16.10.235”
[2024-05-27 02:21:56,327]=11:21:56= INFO [OV-Streaming-Client: main] {00003F60} - Setting log level to ‘E’
[2024-05-27 02:21:56,846]=11:21:56= ERROR [WiFiUtil] {00003F60} - Creating WLAN handle failed : 1062
[2024-05-27 02:21:57,245]=11:21:57= ERROR [Geronimo::Analytics] {00003F60} - Failed to load dll: 지정된 모듈을 찾을 수 없습니다.
[2024-05-27 02:21:57,519]=11:21:57= ERROR [BifrostClient: Streamer] {00003F60} - updateVideoSettingsForNVbProfile: profile 8 is not handled
[2024-05-27 02:21:57,635]=11:21:57= ERROR [NVST:ClientSession] {00004770} - Cannot get server options - 172.16.10.235:48010 via RTSP, 2148016528:NOT FOUND
[2024-05-27 02:21:57,635]=11:21:57= ERROR [NVST:ClientSession] {00004770} - Failed to connect to server using RTSP handshake (error codes: 0X80082190 0000000000)
[2024-05-27 02:21:57,635]=11:21:57= ERROR [NVST:ClientSession] {00004770} - Failed to create RTSP connection with error 0X80082190
[2024-05-27 02:21:57,635]=11:21:57= ERROR [NVST:ClientLibraryWrapper] {00004770} - Could not create initial streaming connection : 0x80082190
[2024-05-27 02:21:57,636]=11:21:57= ERROR [BifrostClient: Streamer] {00004770} - Failed to initiate connection to rtsp://172.16.10.235:48010: Error: NVSTE_RTSP_OPTIONS_RESPONSE_CODE_BAD_REQUEST (0x80082190)
[2024-05-27 02:21:57,636]=11:21:57= ERROR [BifrostClient: Streamer] {00004770} - Streamer connection failure. Error: NVSTE_RTSP_OPTIONS_RESPONSE_CODE_BAD_REQUEST (0x80082190)
[2024-05-27 02:21:57,636]=11:21:57= ERROR [BifrostClient: SessionController] {00004770} - Failed to start the streamer for session 71e1eac8-9f5a-41a8-a8ff-89d5cb29a39d. Aborting the session.
[2024-05-27 02:21:57,636]=11:21:57= ERROR [RemoteGridApp] {000046A0} - STREAMING: FAILED: NVB_SN_STREAMING_START_FAILED (80082190)
[2024-05-27 02:21:57,834]=11:21:57= ERROR [HTTPWin] {000039B4} - Encountered a general WinHttp request error 12017
