I can't install omniverse code 2023.1.1
When I install Omniverse code 2023.1.1 it stucks at : installing pull kit sdk.bat
I have tried the cleanup tool for omniverse. I reinstalled all of my applications but still get the same error.
Capture
Here is my log file :
logs.zip (808.0 KB)
@asterioschou i am just another user, but how long did you let the installation process run (my experiences seem to be the installation for PULL KIT SDK.BAT for each OV app varies)? have you tried rebooting and attempt installation again right after clean boot up?
Thank you very much for your reply! I rebooted the computer, and after that, I proceeded with the installation for almost 20 minutes.
do you mind uploading the OV Launcher log again with the latest attempt? %userprofile%\.nvidia-omniverse\logs\launcher.log
Well, I tried to give it more time for the installation, and almost after 2 hours, it was installed successfully! Thank you very much for your help!!!
2 hours 👀? that…doesn’t sound normal. but glad it worked eventually!
