I run into this error while installing pytorch : libmpi_cxx.so.20: cannot open shared object file: No such file or directory
i am using Jetpack 5.1 (L4T 35.2.1) and i am trying to install pytorch v1.14.0 and torchvision v0.14.1 and while following the steps found on PyTorch for Jetson when i have to run python3 setup.py install --user i get this error : libmpi_cxx.so.20: cannot open shared object file: No such file or directory
any advices?
btw i have just flashed the jetson
Please check below comment:
hi. thanks for the fast replay
i saw that link myself but i can’t acces it i don’t know why
and i remember i ran those commands before installing
shoud i uninstall it and reinstall it ?
guys i solved it, i made a mistake:
i didn’t change the url in wget -O <file_name>
thanks for help anyway
btw how do i get that url, i found an example on Deploy YOLOv8 with TensorRT and DeepStream SDK | Seeed Studio Wiki , but i still don’t know how to get the url
Do you mean the below command?
For example, JetPack 5.1/Pytorch 1.14:
$ wget https://developer.download.nvidia.com/compute/redist/jp/v51/pytorch/torch-1.14.0a0+44dac51c.nv23.02-cp38-cp38-linux_aarch64.whl
If yes, the URL link can be found on the topic of the comment (right-click ->copy URL).
I have similar problem. I’m using Jetpack 5.1.2-b104 and I’m trying to install pytorch v1.6.0 from .whl file in virtual environment with python 3.6.8. Installation goes well. When I list libraries using pip list I see torch 1.6.0 However when I try to import torch in python terminal script I see error mentioned above. I used sudo apt-get install libopenblas-base libopenmpi-dev. I prefer not to use docker
@tomasz.niedzialkowski there is not a PyTorch 1.6.0 wheel that we’ve built for JetPack 5.1.2 and Ubuntu 20.04, so my guess is that you’ve installed one of the wheels that was built against JetPack 4 and Ubuntu 18.04. 18.04 and 20.04 ship with different dependency versions (like the libmpi version is different). Instead, install one of the PyTorch wheels built for JetPack 5.
