I want to save frames after inference, it doesnt work despite adding nvvideoconvert and capsfilter
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.4
• TensorRT Version
I have a deepstream app, that has multiple sgie’s. I have added probe on nvosd, where i check that if a vehicle is of Truck type, i want to save the current frame. This is my code, it doesnt work
obj_meta_list = frame_meta.obj_meta_list
while obj_meta_list:
try:
obj_meta = pyds.NvDsObjectMeta.cast(obj_meta_list.data)
detection = obj_meta.class_id
vehicleType = class_id_to_vehicle_type.get(detection, “Unknown”)
            if vehicleType == "Truck":  # Save frame for Truck if violation detected
                save_violation_frame(frame_image, obj_data["tracking_id"])
def save_violation_frame(frame, tracking_id):
filename = os.path.join(violation_folder, f"violation_{tracking_id}.jpg")
cv2.imwrite(filename, frame)
logging.info(f"Violation frame saved as {filename}")
def get_frame_image(batch_meta, frame_meta):
n_frame = pyds.get_nvds_buf_surface(hash(batch_meta), frame_meta.batch_id)
    frame_image = cv2.cvtColor(n_frame, cv2.COLOR_RGBA2BGR)
return frame_image
I tried hashing from gstbuffer
def get_frame_image(gst_buffer, frame_meta):
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
frame_image = np.array(n_frame, copy=True, order='C')
if frame_image.shape[2] == 4:  # RGBA format
    frame_image = cv2.cvtColor(frame_image, cv2.COLOR_RGBA2BGR)
elif frame_image.shape[2] == 3:  # RGB format
    frame_image = cv2.cvtColor(frame_image, cv2.COLOR_RGB2BGR)
I get this error:
File “/home/a2i/Downloads/deep_app_stable/deepstream_lpr_app-master/deepstream-lpr-app/myapp.py”, line 556, in tiler_src_pad_buffer_probe
frame_image = get_frame_image(gst_buffer, frame_meta)
File “/home/a2i/Downloads/deep_app_stable/deepstream_lpr_app-master/deepstream-lpr-app/myapp.py”, line 347, in get_frame_image
RuntimeError: get_nvds_buf_Surface: Currently we only support RGBA/RGB color Format
any help from anyone would be appreciated
You need to add a nvvideoconvert to change the color format to RGBA. Please refer to our demo code deepstream_imagedata-multistream.py.
I have added this already
Video convert for this stream
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", f"nvvidconv_{i}")
    if not nvvidconv:
        sys.stderr.write(f" Unable to create nvvidconv_{i}\n")
    pipeline.add(nvvidconv)
    elements['nvvidconv'] = nvvidconv
and here how i link:
link the complete chain for this stream
        demuxsrcpad.link(queuesinkpad)
        elements['queue'].link(elements['nvvidconv'])
        elements['nvvidconv'].link(elements['nvosd'])
        elements['nvosd'].link(elements['capsfilter'])
whats wrong? can somebody guide?
You can read the demo code that I attached before.
...pgie->nvvidconv1->filter1...
The nvvidconv1 plugin and filter1 plugin can change the color format of the image to RGBA.
Thankyou for your reply, but when i try to insert a filter in my pipeline i get a quark not negotiated -4 error
i tried the sample app and the frames get saved perfectly, but not with my custom pipeline
        elements['nvvidconv'].link(elements['capsfilter_rgba'])
        elements['capsfilter_rgba'].link(elements['nvosd'])
        elements['capsfilter'].link(elements['encoder'])
        elements['encoder'].link(elements['h264parser'])
        elements['h264parser'].link(elements['muxer'])
        elements['muxer'].link(elements['queue_hls'])
        elements['queue_hls'].link(elements['hlssink'])
Please refer to our demo source code I attached before. You need to set caps to the capsfilter_rgba plugin first.
Since our sample app can work normally. Please take a brief look at the source code first, and then make your own customization.
