I had change the deepstream_sdk_v4.0_jetson\sources\apps\apps-common\src\deepstream_source_bin.c
file code to the pipeline which it suggested like as jhchris713 post# 7 from How to change source pixel format from YUYV to MJPG.
I rebuilt it which you suggested like as post# 9 from How to change source pixel format from YUYV to MJPG.
my computer environment:
Jetson Nano
deepstream_sdk_v4.0.2
my camera information:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.005s (210.000 fps)
Index : 1
unexpectedly, I had error with deepstream-app
like below:
dlinano@jetson-nano:~/deepstream_sdk_v4.0.2_jetson$ deepstream-app -c samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
(deepstream-app:12143): GStreamer-WARNING **: 00:01:31.744: Name 'src_cap_filter' is not unique in bin 'src_sub_bin0', not adding
Creating LL OSD context new
0:00:01.431210334 12143 0x27feab00 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:useEngineFile(): Failed to read from model engine file
0:00:01.431304350 12143 0x27feab00 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.431603588 12143 0x27feab00 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:01:52.945888838 12143 0x27feab00 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/dlinano/deepstream_sdk_v4.0.2_jetson/samples/models/Primary_Detector/resnet10.caffemodel_b1_fp16.engine
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
** INFO: <bus_callback:175>: Pipeline running
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
Quitting
App run failed
And I had the error messages with execute the gst-launch-1.0
command like as below:
dlinano@jetson-nano:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=320,height=240,framerate=60/1 ! videoconvert ! video/x-raw,format=NV12 ! nvvideoconvert ! 'video/x-raw(memory:NVMM)' ! fpsdisplaysink text-overlay=0 video-sink=nvoverlaysink -v
output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0: sync = true
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Any advise for me is much appreciated. Thanks!
