If i use Graph Composer to create a pipeline, could i get the whole code of this pipeline?
if i use Graph Composer to create a pipeline, could i get the whole code of this pipeline?
What do you mean by “code”?
If I use Graph Composer to create a pipeline, I can obtain the underlying Code?
If you use Graph Composer to create a pipeline, you will get the pipeline graph. The graph can be explained and run by GXE Overview — DeepStream documentation 6.4 documentation
To generate pipeline with Graph Composer is just to construct pipeline, there is no code. It is not an IDE tool.
ok. i see. thank you so much.
