i’m working on getting a touchscreen with an Ilitek-2132 controller running with the Jetson Nano production module.
For that, I backportet the touchscreen driver module ilitek_ts_i2c (attached) to the tegra-kernel4.9 provided with L4T_32.7.2 and enabled the touchscreen in the devicetree as follows:
touchscreen_i2c0: i2c@7000c000 {
touchscreen@41 {
compatible = "ilitek,ili2132";
reg = <0x41>;
interrupt-parent = <&gpio>;
interrupts = <&gpio TEGRA_GPIO(CC, 0) IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&gpio TEGRA_GPIO(CC, 6) GPIO_ACTIVE_LOW>;
touchscreen-inverted-y;
wakeup-source;
The driver module initializes correctly as far as i can tell from the added debug statements. But the i2c read during the interrupt handler fails to get any data, the irq-handler fails and the cpu crashes.
When i run the i2c commands, that the driver issues from a python script, i am able to read touchcontroller data.
Do you have any hints regarding special requirements for i2c communication from an ISR on the Tegra X1, or on how to find the root-cause for the crash?
[ 500.293687] ilitek_ts_i2c: (ilitek_ts_i2c_probe): --enter probe–
[ 501.310083] ilitek_ts_i2c: (ilitek_protocol_init): --enter–
[ 501.315875] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.321729] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x42 w_len:1 r_len:3
[ 501.335310] ilitek_ts_i2c: (ilitek_read_tp_info): --enter–
[ 501.341091] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.347529] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x42 w_len:1 r_len:3
[ 501.361903] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.367709] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x61 w_len:1 r_len:32
[ 501.382035] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.388067] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x40 w_len:1 r_len:8
[ 501.403804] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.409532] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x21 w_len:1 r_len:8
[ 501.423293] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.428999] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x20 w_len:1 r_len:15
[ 501.444089] ilitek_ts_i2c: (api_protocol_set_cmd): --enter–
[ 501.449899] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0xc0 w_len:1 r_len:2
[ 501.463502] ilitek_ts_i2c: (ilitek_input_dev_init): --enter–
[ 501.469781] ilitek_ts_i2c: (ilitek_ts_i2c_probe): ilitek reg irq: 189
[ 501.476978] ilitek_ts_i2c: (ilitek_i2c_isr): --enter isr irq:189 –
[ 501.483308] ilitek_ts_i2c: (ilitek_process_and_report_v6): --process_and_report–
[ 501.490846] ilitek_ts_i2c: (ilitek_process_and_report_v6): #1
[ 501.496632] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x0 w_len:0 r_len:64
[ 502.814642] irq 189: nobody cared (try booting with the “irqpoll” option)
[ 502.822801] handlers:
[ 502.825217] [] irq_default_primary_handler threaded [] ilitek_i2c_isr [ilitek_ts_i2c]
[ 502.836741] Disabling IRQ #189
[ 511.611291] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4
[ 511.615216] tegra-i2c 7000c000.i2c: rx dma timeout txlen:12 rxlen:64
[ 511.615236] tegra-i2c 7000c000.i2c: — register dump for debugging ----
[ 511.615255] tegra-i2c 7000c000.i2c: I2C_CNFG - 0x22c00
[ 511.615273] tegra-i2c 7000c000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001
[ 511.615291] tegra-i2c 7000c000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 511.615308] tegra-i2c 7000c000.i2c: I2C_FIFO_STATUS - 0x800080
[ 511.615325] tegra-i2c 7000c000.i2c: I2C_INT_MASK - 0x6c
[ 511.615340] tegra-i2c 7000c000.i2c: I2C_INT_STATUS - 0xc2
[ 511.615396] tegra-i2c 7000c000.i2c: i2c transfer timed out addr: 0x41
[ 511.615482] ilitek_ts_i2c: (ilitek_i2c_write_and_read): i2c_transfer #3 error=-110
[ 511.615505] ilitek_ts 0-0041: get touch info failed, err:-110
[ 511.615557] ilitek_ts 0-0041: [ilitek_i2c_isr] err:-110
[ 511.615582] ilitek_ts_i2c: (ilitek_i2c_isr): --enter isr irq:189 –
[ 511.615593] ilitek_ts_i2c: (ilitek_process_and_report_v6): --process_and_report–
[ 511.615601] ilitek_ts_i2c: (ilitek_process_and_report_v6): #1
[ 511.615617] ilitek_ts_i2c: (ilitek_i2c_write_and_read): addr:0x41 cmd:0x0 w_len:0 r_len:64
[ 511.723257] tegra-i2c 7000d000.i2c: — register dump for debugging ----
[ 511.730384] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00
[ 511.735862] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001
[ 511.743149] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 511.749055] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081
[ 511.755286] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d
[ 511.760860] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3
[ 511.766595] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c
[ 521.851278] tegra-i2c 7000c000.i2c: rx dma timeout txlen:12 rxlen:64
[ 521.855206] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4
[ 521.855225] tegra-i2c 7000d000.i2c: — register dump for debugging ----
[ 521.855245] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00
[ 521.855263] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001
[ 521.855280] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 521.855296] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081
[ 521.855314] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d
[ 521.855329] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3
[ 521.855349] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c
[ 521.855472] Failed to set dvfs regulator vdd-core
[ 522.062198] tegra-i2c 7000c000.i2c: — register dump for debugging ----
[ 522.083269] tegra-i2c 7000c000.i2c: I2C_CNFG - 0x22c00
[ 522.102636] tegra-i2c 7000c000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001
[ 522.123809] tegra-i2c 7000c000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 522.143467] tegra-i2c 7000c000.i2c: I2C_FIFO_STATUS - 0x800080
[ 522.163239] tegra-i2c 7000c000.i2c: I2C_INT_MASK - 0x6c
[ 522.182130] tegra-i2c 7000c000.i2c: I2C_INT_STATUS - 0xc2
[ 522.201079] tegra-i2c 7000c000.i2c: i2c transfer timed out addr: 0x41
[ 522.221019] ilitek_ts_i2c: (ilitek_i2c_write_and_read): i2c_transfer #3 error=-110
[ 522.242124] ilitek_ts 0-0041: get touch info failed, err:-110
[ 522.261647] ilitek_ts 0-0041: [ilitek_i2c_isr] err:-110
[ 522.482856] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 522.502059] 0-…: (1 GPs behind) idle=b09/140000000000001/0 softirq=31957/31958 fqs=2469
[ 522.523866] (detected by 2, t=5262 jiffies, g=8586, c=8585, q=10256)
[ 523.239082] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 523.258117] 0-…: (1 GPs behind) idle=b09/140000000000001/0 softirq=31936/31958 fqs=2491
[ 523.280099] (detected by 3, t=5252 jiffies, g=3800, c=3799, q=699)
[ 528.343043] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 0
[ 528.364208] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.9.253-tegra #10
[ 528.384710] Hardware name: Anvajo FL2_CBv2 (DT)
[ 528.403035] Call trace:
[ 528.419238] [] dump_backtrace+0x0/0x1a0
[ 528.438424] [] show_stack+0x24/0x30
[ 528.457140] [] dump_stack+0xa0/0xc4
[ 528.475740] [] panic+0x124/0x29c
[ 528.493926] [] watchdog_check_hardlockup_other_cpu+0x11c/0x120
[ 528.514803] [] watchdog_timer_fn+0x98/0x2c0
[ 528.533922] [] __hrtimer_run_queues+0xd8/0x360
[ 528.553224] [] hrtimer_interrupt+0xa8/0x1e0
[ 528.572142] [] tegra210_timer_isr+0x38/0x48
[ 528.590970] [] __handle_irq_event_percpu+0x68/0x288
[ 528.610438] [] handle_irq_event_percpu+0x28/0x60
[ 528.629595] [] handle_irq_event+0x50/0x80
[ 528.648014] [] handle_fasteoi_irq+0xd4/0x1c0
[ 528.666703] [] generic_handle_irq+0x34/0x50
[ 528.685279] [] __handle_domain_irq+0x68/0xc0
[ 528.703924] [] gic_handle_irq+0x5c/0xb0
[ 528.722142] [] el1_irq+0xe8/0x194
[ 528.739742] [] cpuidle_enter_state+0xb8/0x380
[ 528.758239] [] cpuidle_enter+0x34/0x48
[ 528.775986] [] call_cpuidle+0x44/0x70
[ 528.793486] [] cpu_startup_entry+0x1b0/0x200
[ 528.811425] [] secondary_start_kernel+0x190/0x1f8
[ 528.829834] [<0000000080f7c1a8>] 0x80f7c1a8
[ 528.846049] SMP: stopping secondary CPUs
[ 528.862225] Kernel Offset: disabled
[ 528.877721] Memory Limit: none
[ 528.937451] —[ end Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 0
ilitek_ts_i2c.c (16.1 KB)
Best regards,
Johannes
