hello guys,
I follow the Flux & ComfyUI instruction to run ComfyUI on Jetson. In step 9, the link to workflow download is invalid(404 not found) Who can tell me how to download workflow elsewhere ?
hello guys,
We don’t have experience on this, may other developer help to provide suggestions.
Hello. What problem do you have?
I’m the author of these containers.
I’m writing the tutorial on jetson lab
I got the same problem. At the below step:
I also see an error 404 (file not found). I also tried to go to the containing directory, https://www.jetson-ai-lab.com/assets/, and apparently the directory itself does not exist (perhaps it has a different name now).
I figured out that we don’t need the workflow file in step 9. We can download/save the images in the tutorial and it will regenerate the workflow for us.
So if you follow all the steps correctly and you can open the url ComfyUI (127.0.0.1:8188). Then you can click Load button and select any image that you downloaded. After that click Queue Prompt and it will take some time to generate a new image. You can see the downloading process in the terminal. Hope it help.
It’s not uploaded from the original tutorial
