I’m fairly sure that using NPP Perspective Transform introduces a strange error in my images that causes black lines (stripes) to appear on the lft side.
First, I use nppiWarpPerspective_8u_C1R to register my image to certain coordinates. The result looks ok. However, when I display the image later it has to be resized to fit the display window. This resizing causes black lines to appear on the left side.
After some tests I think this is introduced in the WarpPerspective function. Is this problem known? Any ideas on what causes it and what to do about it?
I have attached a bmp file that has the described problem. Notice how the lines on the left change when you resize the bmp, for example by zooming in IrfanView.
