Hello Guys,
I just got a Jetson Nano and created my SD-Card with Jetpack 4.6.1. After that I installed TensorFlow like this:
Tensorflow-Install
Than I wanted to create an mnist Model but it seems like I cant import Keras? Any Idea ?
I just install Tensorflow and upgraded all apt-get packages.
>>> import tensorflow.keras
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/keras/api/_v2/keras/__init__.py", line 12, in <module>
from keras import __version__
File "/usr/local/lib/python3.6/dist-packages/keras/__init__.py", line 24, in <module>
from keras import models
File "/usr/local/lib/python3.6/dist-packages/keras/models/__init__.py", line 18, in <module>
from keras.engine.functional import Functional
File "/usr/local/lib/python3.6/dist-packages/keras/engine/functional.py", line 24, in <module>
from keras.dtensor import layout_map as layout_map_lib
File "/usr/local/lib/python3.6/dist-packages/keras/dtensor/__init__.py", line 22, in <module>
from tensorflow.compat.v2.experimental import dtensor as dtensor_api # pylint: disable=g-import-not-at-top
ImportError: cannot import name 'dtensor'
This is the full Error log. I started python3 as sudo
Could you share how do you install the TensorFlow package?
We confirm that importing Keras with the l4t-tensorflow:r32.7.1-tf2.7-py3 container is working.
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-tensorflow:r32.7.1-tf2.7-py3
root@nvidia-desktop:/# python3
Python 3.6.9 (default, Dec 8 2021, 21:08:43)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import keras
I first did a clean install of JetPack 4.6.1 and than I installed the dependencies exactly like the docs:
Before you install TensorFlow for Jetson, ensure you:
- Install JetPack on your Jetson device.
- Install system packages required by TensorFlow:
$ sudo apt-get update $ sudo apt-get install libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-dev liblapack-dev libblas-dev gfortran
- Install and upgrade pip3.
$ sudo apt-get install python3-pip $ sudo pip3 install -U pip testresources setuptools==49.6.0
- Install the Python package dependencies.
$ sudo pip3 install -U --no-deps numpy==1.19.4 future==0.18.2 mock==3.0.5 keras_preprocessing==1.1.2 keras_applications==1.0.8 gast==0.4.0 protobuf pybind11 cython pkgconfig $ sudo env H5PY_SETUP_REQUIRES=0 pip3 install -U h5py==3.1.0
After that I install Tensorflow for Jetpack 4.6.1 like this:
sudo pip3 install --pre --extra-index-url Index of /compute/redist/jp/v461 tensorflow
Are there any performance drawbacks with using a docker and why do I have to install everything as sudo?
