ImportError: OpenCV loader: missing configuration file: ['config.py']. Check OpenCV installation
I’m trying to binarize my python application on Jetson Nano, Jetpack 4.2.1 using pyinstaller. But when run the binary file, I got this error:
ImportError: OpenCV loader: missing configuration file: ['config.py']. Check OpenCV installation.
Can someone help me?
Sorry for the late response, have you resolved the issue or still need the support?
Any result can be shared?
I have the same problem
I was able to get around this issue by including the path to OpenCV when running pyinstaller like this:
pyinstaller --paths='/usr/local/lib/python3.6/dist-packages/cv2/python-3.6'
or by adding it to the spec file like this:
pathex=['/usr/local/lib/python3.6/dist-packages/cv2/python-3.6', '/home/me/bundle']
