When batch size is 1 everything is OK ;
When batch size is 2,logs is :
NFO: [TRT]: Detected 1 inputs and 12 output network tensors.
0:06:32.594657194 2361 0x55866b2af0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 10001]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1752> [UID = 10001]: serialize cuda engine to file: /home/nvidia/model/gelanbo/gelanbo.onnx_b2_gpu0_fp16.engine successfully
ERROR: [TRT]: pred_lbbox/reshape: reshaping failed for tensor: conv_lbbox/BiasAdd__144:0
ERROR: [TRT]: shapeMachine.cpp (160) - Shape Error in executeReshape: reshape would change volume
ERROR: [TRT]: Instruction: RESHAPE_ZERO_IS_PLACEHOLDER{2 16 16 30} {1 16 16 3 10}
INFO: [FullDims Engine Info]: layers num: 4
0 INPUT kFLOAT Placeholder/inputs_x:0 3x512x512 min: 1x3x512x512 opt: 2x3x512x512 Max: 2x3x512x512
1 OUTPUT kFLOAT pred_lbbox/decode:0 16x16x3x10 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT pred_mbbox/decode:0 32x32x3x10 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT pred_sbbox/decode:0 64x64x3x10 min: 0 opt: 0 Max: 0
0:06:32.679772443 2361 0x55866b2af0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 10001]: Error in NvDsInferContextImpl::allocateBuffers() <nvdsinfer_context_impl.cpp:1323> [UID = 10001]: Failed to allocate cuda output buffer during context initialization
0:06:32.679981321 2361 0x55866b2af0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 10001]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1173> [UID = 10001]: Failed to allocate buffers
0:06:32.757130607 2361 0x55866b2af0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:06:32.757224821 2361 0x55866b2af0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/galb/pgie_config.txt, NvDsInfer Error: NVDSINFER_CUDA_ERROR
How to fix it
• Hardware Platform (Jetson / GPU) xavier
• DeepStream Version5.0
• TensorRT Version
