In Fedora 37 , with nvidia-driver 520.56.06 from rpmfusion it crash Apex legends in game sometime with the driver in rpmfusion i cannot play properly like some peoples in reddit also
The rpmfusion bug i open 6466 – [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
I cannot link the reddit and fedora forum because i’m a new account but they are in the bugzilla
The same error are here in wayland or x11
[ 74.206924] nvidia: loading out-of-tree module taints kernel.[ 74.206932] nvidia: module license ‘NVIDIA’ taints kernel.[ 74.206933] Disabling lock debugging due to kernel taint[ 74.215326] nvidia: module verification failed: signature and/or required key missing - tainting kernel[ 74.292585] nvidia-nvlink: Nvlink Core is being initialized, major device number 235[ 74.293393] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem[ 74.337681] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 520.56.06 Thu Oct 6 21:38:55 UTC 2022[ 74.390754] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.[ 74.416584] nvidia-uvm: Loaded the UVM driver, major device number 511.[ 74.457747] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 520.56.06 Thu Oct 6 21:22:53 UTC 2022[ 74.461978] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver[ 75.953450] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 510.516218] [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Linux fedora 5.19.16-301.fc37.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Oct 21 15:55:37 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
NVIDIA GeForce RTX™ 3060
nvidia-smi Sat Nov 5 02:26:35 2022 ±----------------------------------------------------------------------------+| NVIDIA-SMI 520.56.06 Driver Version: 520.56.06 CUDA Version: 11.8 |
I got this error on Fedora 37 but not on my Fedora 36 with akmod-nvidia-510.68.02-1.fc36.x86_64.rpm
How can i help to debug this ?
Thanks !
